And now for some 39 year old porn, plastic is a bit delicate as expected but amazingly it is still in calibration, ok, its ex RAF so it has had a few calibration checks in its life but I have no idea when the last one was done, Ni-Cd battery charging board requires attention, someone had a go before and disconnected a couple of diodes and tants, not sure if they spotted the burnt out resistor or not? I'll be working on that soon and then the 7045 will be joining the 3466A in my bench stack.
Push buttons on the Volts, Amps and resistance ranges have seen some use and just catch the case bottom and were sticking in at times, shaved some of the case away and now work OK so may have to replace the switches in time. The ugly duckling cleaned up pretty well considering how scratched the case is but luckily the front panel is in good shape.
![](https://i.imgur.com/LKFchid.jpg)
![](https://i.imgur.com/cMzkOrP.jpg)
![](https://i.imgur.com/eJ0DgO3.jpg)
![](https://i.imgur.com/hCe6wq4.jpg)
![](https://i.imgur.com/6MKuDVO.jpg)
10k 1% resistor
![](https://i.imgur.com/I5E8xEh.jpg)
10v reference from AD584-M
![](https://i.imgur.com/cxW6L7o.jpg)
Same 10V reference from AD584-M on a HP3466A
