Okaaaaayyyy... So, I've been away a while... (damn pesky IRL, always getting in the way of what's IMPORTANT), and I'm just catching up. I've made a long list in my WordPad, but instead of my usual WALL OF TEXT responses, I'm going to try just responding to one or two posts at a time to minimize the ol' "EGOS" ( Eyeballs Glazing Over Syndrome ) and so folks can actually only quote one bit at a time if they wanna retaliate... err, post a reply. I did consider one but the £50 outlay put me off.
T12 is interesting because it is so amazingly cheap.
I'm after something I can run off 12-14V as well. The T12 can't quite manage a decent job of that so I'm going to look at adding a boost converter up front. Will get it on a bench supply first and see what sort of current it pulls.
Edit: incidentally I'm adding a 12V off line power bus to some of the new house when we move in. This will have some equipment attached to it, mainly communications and lighting. Would be nice to be able to do some soldering if the mains goes pop
This actually is the exact reason for my building a SECOND OLED T12 system; to have the joy that is the T12 soldering system in a portable package I can run off a 4S LiPo from and FOR my other hobby, RC model aircraft.
Right now, while I seek out the enclosure I want, I'm bench-flogging
one of these 150W DC-DC 10-32V/12-35V 6A Boost Converters with good results: They're crazy cheap, and pretty compact for the power. Now if I can get an enclosure I like; I just loathe the extruded AL bricks that are so popular with these right now. I may have to suck it up and compromise though, just to get the project finished.
I saw the TS100 review after I had decided and ordered the T12 and I think that the T12 is the better system for bench use. The TS100 uses a modified T12 tip, but its construction is essentially the same.
The TS100 being cordless may be an advantage but it can also be a disadvantage, overall I think I'd personally stick with a corded iron.
The TS100 was what got me started on the OLED T12 journey; it SEEMS like the perfect portable iron in principle; operates on 12V (at half the wattage) to 24V, has 5.5mm coaxial power connector so any old 18-20V laptop power brick you have lying around will work fairly well, plus easy to mod for LiPo power off any old flight pack. But the EXECUTION IS UTTER SHITE.
I ponied up the ridiculous dosh (for a Chineseum soldering iron without a power supply) and bought one almost 2 years ago; the first one arrived with the plastic around the base of the element split wide open from what I assumed was some overzealous screwgun-jockey overtightening a set screw that holds the tip; so I immediately sent it back for replacement. Replacement unit had same handle casting in a different color, but the SAME DAMN CRACK.
Upon disassembly, I discovered the reason why; the inner stem of the TS100 tips is ~25mm long; the tip has HUGE leverage against the plastic of the handle and it feels floppy and flexy like the cheap Chineseum POS it is. Even if one omitted the set screw, it would soon crack exactly the same way as both of mine came from the vendor.
I reassembled mine and returned it for refund and have never looked back.
Cheers,
Lets see how this new tactic works out while I go out on a Work Order...
