Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 18103424 times)
dxl and 45 Guests are viewing this topic.
« Reply #6125 on: January 09, 2018, 11:11:33 am »
In this context, I have no idea, Quicko iron does not use on their version. Here are the photos of the terminations on their supplied handle. EDIT; If you notice, the ball switch or vibration switch terminates on the -ve as does the black wire, this as per my earlier posting, this the 907 handle, the 9501 handle is exactly the same circuit but no sprew/pcb connections are made to the tags as per link.
« Last Edit: January 09, 2018, 11:16:09 am by Specmaster »
« Reply #6126 on: January 09, 2018, 11:24:42 am »
Ok it's just missing then :)
Plan is to just remove the parts from the 907 handle then put them on the table and forget the 907 handle exists. Then follow those 9501 instructions substituting the mercury switch with the ball switch.
Out of interest, was the cable a silicone one?
« Reply #6127 on: January 09, 2018, 12:32:10 pm »
You know, I'm not certain but it certainly feels like it could be.
The 907 handle is not a particularly bad handle to work with, just takes a little getting used to as it did back in the day with mains driven irons
but we learned how to adapt with the different size of iron handles from different makers and sizes.
EDIT, My handle is now with a local shipping company so it could be here as early as tomorrow.
BTW, in those YouTube videos of the LEDs did you spot the soldering irons that most of them were using, they looked like 907 handles to me and had K type tips fitted.
« Last Edit: January 09, 2018, 12:42:41 pm by Specmaster »
« Reply #6128 on: January 09, 2018, 12:40:21 pm »
Not too concerned about working with the handle but the design of it. That PCB frame looks hooky as hell. The 9501 seems to be as solid as rock. It's far more solid even than the Weller handles.
Edit: I didn't see those videos - any references? K tip is what I want. I've got lots of boards of SOIC ICs to drag solder so they look pretty good for that.
« Last Edit: January 09, 2018, 12:43:57 pm by bd139 »
« Reply #6129 on: January 09, 2018, 12:52:23 pm »
The 907 handle in use is just as solid, trust me, my Katsu and and the Quicko both came with a 907 and I never had a moments trouble or concern using that handle on the katsu.
« Reply #6130 on: January 09, 2018, 01:02:50 pm »
Hopefully better than my old Aoyue 937 handle. I'd be quite happily soldering away, watching it burn up a tip because the control loop was busted, and it would literally fall to pieces. The shaft that you screw on to hold the tip on would ping off, the tip would go with it.  :palm:
And you had to turn the cable regularly because there was a break in it somewhere. I never bothered to sort it and just used it as a firestick. I'll do a post mortem on it when I get my hands on it again.
Offline Calambres
    • Piso-Tones
« Reply #6131 on: January 09, 2018, 01:06:53 pm »
... the 4 pin version does not use the thermister, ntc or the capacitor...
Does it mean that the Quicko doesn't have temperature control?  :-//
« Reply #6132 on: January 09, 2018, 01:07:56 pm »
It has temperature control; that thermistor is part of the tip.
« Reply #6133 on: January 09, 2018, 01:08:17 pm »
Around 2.07
« Reply #6134 on: January 09, 2018, 01:17:05 pm »
Well spotted. That is indeed.
Towards the end, that video reminds me of Auferstanden Aus Ruinen a little bit. Even our corporate video isn't as sickening :D
« Reply #6135 on: January 09, 2018, 01:31:01 pm »
 I watched a few Chinese LED factory videos yesterday and some power supply ones and that handle and tip appears loads of times, some of them in close up as well and the think that I gleaned from watching them is that they all seem to take quality as a core requirement and many of them have achieved world standard certificates and most of them do 100% soak / burn in test prior to packing and dispatch. Over here many companies operate on a 10% batch test, even companies like MK Electric who are the biggest producer of wiring accessories and power distribution for the domestic markets operate a 10% testing regime.
I used to work for Crabtree Electrical and Ashley & Rock, both were MK's competitors and both did a 100% test of each item and also spot checks at random points in a production cycle to ensure quality.
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #6136 on: January 09, 2018, 04:08:17 pm »
Get ready for a one year anniversary party for the TEA thread in a week!
Thread started by Bitseeker: January 16, 2017
 :popcorn:
The following users thanked this post: SeanB, bitseeker, gnavigator1007
Offline neo
  • The specialist.
« Reply #6137 on: January 09, 2018, 04:15:01 pm »
Wow, 246+ pages in a year.
I must concur with the mad hatter, we are all mad here.
« Reply #6138 on: January 09, 2018, 04:18:59 pm »
Speak for yourself, some of us are still with it, what that it is however I have no frigging idea. 🤣🤣
« Last Edit: January 09, 2018, 06:26:24 pm by Specmaster »
The following users thanked this post: neo
Offline AF6LJ
« Reply #6139 on: January 09, 2018, 04:49:04 pm »
We are a bunch of enablers. :D
Someone once asked why we all have 20 Oscilloscopes and 20 DMMs>
Hell Why not. :P
Indeed! :-+
I was hoping to get my workbench all tidied up over the holidays, so I could have a nice arrangement of equipment on/around it. Well, that failed. :-DD
I know how that goes....
The real world tends to get in the way of what WE would rather be doing.
Sue AF6LJ
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #6140 on: January 09, 2018, 05:41:48 pm »
 :popcorn:
Quick - everyone get to evilBay and order something for delivery on the 16th!
-Pat
« Reply #6141 on: January 09, 2018, 07:36:31 pm »
Judging by how I’ve been battering aliexpress this month I’ll be carpet bombed on the 16th.
« Reply #6142 on: January 09, 2018, 08:41:55 pm »
I've got loads of stuff coming from Ebay, Banggood and AliExpress this month so my hallway could be a complete mess with stuff or completely devoid, it all hinges on the carriers. ;D
« Reply #6143 on: January 09, 2018, 09:28:38 pm »
I'm trying, but you know how it goes — those crazy folks start bidding early and/or bid waaay too much. Maybe I should sell stuff before all the crazy bidders run out of money. :-DD
« Reply #6144 on: January 09, 2018, 09:50:03 pm »
I’m actually trying to shift a power supply at the moment (my E3630A). Keep getting stupid offers so I assume they’re all broke here.
Offline AF6LJ
« Reply #6145 on: January 09, 2018, 10:09:38 pm »
 :popcorn:
-Pat
Gotta have money to do that.
I shot my wad this month already.
I think I am used up for next month also....
Will have to see.
Sue AF6LJ
« Reply #6146 on: January 09, 2018, 10:12:41 pm »
So, is the power supply reading low or your meter reading high   :-//
Don't forget, their still getting their credit cards paid off from the caning it got over Christmas  :-DD
« Reply #6147 on: January 09, 2018, 10:47:15 pm »
It was cold in there - PSU was warming up :)
Yes I’m paying mine off as well.  Bang goes my bonus. And got to pay for all the shit I forgot to budget for when moving house which appears to be quite a bit.
Other half landed a job earlier this week at a posh salon so earns nearly as much as I do though. Phew. Perhaps I should retire now  :-DD
« Last Edit: January 09, 2018, 10:49:06 pm by bd139 »
« Reply #6148 on: January 09, 2018, 11:05:25 pm »
But that would mean having to give up TEA, COFFEE and BISCUITS, no frigging way.  :-DD
Offline Mr. Scram
  • Display aficionado
« Reply #6149 on: January 09, 2018, 11:05:40 pm »
As a bonus, she can get those stupidly expensive haircuts for free!
