The difference in the 4 wire and the 5 wire handles must reflect the way that the controllers expect to see the signals.
The 4 wire as on the Quicko has the following connections.
On the original posting I assumed that the pin terminology was from the terminal side not the other side so my number system was in correct, here is the rectified version
Pin 1 green is the earth on the handle
Pin 2 Red is the live on the handle
Pin 3 Blue goes to the input side of the ball switch. The output side of the ball switch goes to the negative on the handle.
Pin 4 Black is the negative on the handle
So the ball switch connects from the -ve terminal back to the processor to wake up the iron and either bring it out of the "Power Off" or the "Sleeping" mode.
On the 5 pin system.
Pin 5 Black is the -ve on the handle
Pin 4 White is the Thermistor in the handle
Pin 3 Green is the earth on the handle
Pin 2 Blue is the feed to the ball switch, output on the ball switch goes earth on the handle.
Pin 1 Red is the live +ve on the handle
So the ball switch connects from the Earth terminal back to the processor to wake up the iron and either bring it out of the "Power Off" or the "Sleeping" mode.
So to make the 9501 handle compatible with the 952 station as made by Quicko requires the following modifications
On the socket end
1/ Replace the 5 pin aviation socket with a 4 pin.
2/ connect Green to pin 1
3/ connect Red to pin 2
4/ connect Blue to pin 3 (blue is already connected to ball switch in handle)
5/ connect Black to pin 4
6/ cut out the White core
At the handle end
7/ remove the ball switch output from Earth and reconnect to heater -ve & Black
8/ cut out the White core and remove the thermistor
The system should then run OK.
pasted direct from Ali Express site, these are the connections to the AIYIMA Modified FX-9501 Handle For T12 Oled Digital Display Soldering Station Silicone Line Handle DIY
"FX-9501 Handle connection wiring:
1 feet (red line) ---- P + (heating core heating +)
5 feet (black line) ---- P- (heating core heating -)
4 feet (blue line) ---- S (ball switch)
3 feet (green line) ---- E (ground)
2 feet (white line) ---- N (thermistor)"
So you can see the blue wire is already terminated to the ball switch so best to reuse that wire and cut out the white core (connected to the thermistor) as we are not using the thermistor.
