Suppose I had better chase up manuals, circuit diagrams and such for a HP 5381A counter ![Broken! :-BROKE](https://www.eevblog.com/forum/Smileys/default/smiliey_scope_broke.gif)
Lucky I have a couple of nice German Polytron OCXO oscillators 'laying around' to install. This is WHY WE BUY STUFF just in case ![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
It is much better to have it and not need it, than to need it and not have it.
-Pat
Yeah... this is how I wound up with a garage full of boxes stacked 6 feet high full of stuff I bought "Just in case I need it" and "For this project bouncing around the back of my head".
I have TEAS, only in a much BROADER range of disciplines including auto repair/customizing, general Electronics tinkery, Computer repair & IT Service (my actual job right now), metal fab/welding, and recently hobby woodworking which started with finding a huge 10" table saw on the curb, then a couple of "fixable" routers and grew to include drum sanders and scrollsaws.
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
Oh, and then there's my MAIN hobby... RC aircraft.
Then when it comes time to put up the Christmas tree, EVERYTHING that gets moved to make room winds up in my office/workbench area and I can barely lean back in my chair at the bench.
![Tongue :P](https://www.eevblog.com/forum/Smileys/default/tongue.gif)
And the worst part is... at least half the time, when I DO decide to get into one of those "projects bouncing around the back of my head" I either wind up putting it off or worse, buying new components online due to the assache of actually GETTING TO the components I know I have...
I think the first thing they should do is to update the display, I don't think unlit LCD cuts it anymore. How many workshops have really good lighting levels behind you? Most of them have task lighting above the bench which if your test gear is on the bench means trouble reading the displays. [emoji21]
LCD displays are cheap, super low power, robust and have great longevity. I don't know where you'd want to go, but most other technologies are far inferior. I know those TFT screens look sweet and sexy, but you can bet they won't last as long as LCD or LED displays.
I've actually intentionally looked for LCD or LED displays for most my devices. VFD is good too and looks amazing, though it's more susceptible to wear.
I know I'm going to get a lot of flakk for this because of the inherent longevity issues, but I really wish they'd make larger OLEDs in standardized formats like they do matrix LCDs. I mean they do, but they're ridiculously expensive because the push is always towards higher pixel density right now. I think a nice 80-100PPI OLED with SPI or even I²C bus in various square and wide formats as matrix LCDs are made would be a great idea, and honestly, they're the only display tech I like almost as much as VFD. If they were made as a standardized commodity item like matrix LCDs or even a package like 8-segment LEDs for stacking to size, it would be easy to find suitable replacements even 20 year later, just as it is now with matrix LCDs and 8-segment LEDs.
I'm a compulsive obsessive cleaner so clutter does my head in. This helps ![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
The lack of space here means I absolutely cannot afford to be allergic to clutter. It simply won't fly.
1000x this. Don't get me wrong... every once in a while I hoe it all out; you HAVE TO. But "organized chaos" is the rule of the day on my bench half the time. That I'm there. Working. When I don't have the door closed. And my wife might be home.
![Bullshit Detector :bullshit:](https://www.eevblog.com/forum/Smileys/default/BullshitDetector.gif)
Umm... no. You still apply the LEDs so they face directly against the edge of the LCD; look again at the first photo. They work great, as you can see in the pics below. If you're worried about light spilling, you just wrap with a layer of kapton tape, then AL foil, then kapton tape to make a light channel. Or do the same around the inside edges of the bezel.
This space For Rent.
Further investigation of the counter looks like it will be very difficult to provide some lighting to the screen, especially using LED tape as you did. I tried it last night by laying a stretch of the tape across the top of the gap between the front plate and the pcb and the LCD screen is very close to this edge, effect on the screen, nil but plenty of light spill to edges of the bezel.
Unlike your RC module, the counter does not have a secondary window, the LCD is stepped so it fits into the bezel and finishes almost flush with the front panel. This leaves the thinnest of open glass edges to capture the light and channel it through the LCD panel itself. Also when I presented the section of LEDs to the screen in the region of the counting section of the PCB, the counter sprung into life and started counting. This shows that area is very sensitive to spurious signals but that might have been because the LEDs were powered from a wall wart, maybe better smoothing would prevent it. Total gap between front plate and the PCB is 4mm so there is not a lot of space to play with either.
Hmmm... if you were powering the light from an RGB controller, multiple PWM channels would certainly generate some noise the counter could pick up.
It sucks that this display is flush/recessed mount; sounds like your only other option would be to make a diffuser from scratch to go behind the LCD, and this would only work if is is NOT one of those with an opaque reflector. Most are at least somewhat translucent, though.
What are the dimensions of the LCD, and how much gap is there between it and the PCB behind it? I may know of something ready-made that could be cut to fit.
I'm all out of "pithy" right now.
