They bounce though ![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
So do my kids, but that doesn't mean I want to stick ugly chunks of rubber on all their corners.
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
I still can't find a reason why anyone would need an 8.5 digit meter. Please enlighten me ![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
- playing around with the edge of the envelope
- bragging rights
- so you can use a Weston standard cell as a thermometer
- just because
- you are asking us that? Go and wash your mouth out with soap
I keep my scales numbered for just such occasions...
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
A funny thought occurred to me, i have four 3.5 digit, three 4.5 digit and two 5.5 digit multimeters.
It seems as if my test equipment is ganging together to tell me i need 6.5 next... ![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
OK, sounds like a mathematically well-defined buying list. ![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
So you want to increase your stock by three 3.5 digit, three 4.5 digit, three 5.5 digit, three 6.5 digit, two 7.5 digit multimeters for adding a 8.5 digit multimeter finally..
![Popcorn :popcorn:](https://www.eevblog.com/forum/Smileys/default/EatingPopcorn.jpg)
That'd break the pyramid and minimize GAS. What you need is something like the following:
8.5
7.5 7.5
6.5 6.5 6.5
5.5 5.5 5.5 5.5
4.5 4.5 4.5 4.5 4.5
3.5 3.5 3.5 3.5 3.5 3.5
And then I can come along with a 1KVA toroidal transformer, and try for the 3.5-3.5 split after almost making the tournament-winning strike.
![Scared :scared:](https://www.eevblog.com/forum/Smileys/default/scared.gif)
Here as promised are the teardown photos showing the display and it might be possible to mount some white LEDs around the edge of the display as it has glass edges exposed and is raised up from the pcb. I'll investigate this a bit more but they would to be switched via switc on the back plate because it is also a portable battery powered device and the LEDs would reduce the operating time if they were on all the time.
![](https://i.imgur.com/LZtkNyG.jpg)
Looks to me like a great place to use some
5050 RGB LED strip and a cheap controller. There are Oodles of vendors selling this stuff; should be able to get ~1M of strip and an RF controller for approx US$4.00 or so. Just make sure you get 5V controller and LED strip, not 12V. These modulate 3 PWM channels via ~3A FETs sinked to GND, so the same controllers will usually operate from ~5V up to ~24V DC. The LED Strips come premade with ballast resistors scaled to 5VDC input or 12VDC input. You can cut them to length in groups of 3, so physical sizing is pretty easy.
These controllers are available in all styles; from
a simple 3-button non-remote model to IR and RF remotes with up to 40 settings. Cost is typically $1-10 China-Direct, about double that price for equivalent units here in the US, so I'd guess there should be similarly priced local vendors for most regions.
*Lit as frigg*
