Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 16655427 times)
shakalnokturn, Vgkid, Robert763, klab, Runco990 and 51 Guests are viewing this topic.
« Reply #4375 on: December 05, 2017, 09:08:13 am »
A metcal is what god would have soldered the universe together with, if he existed and could afford the cartridges.
The following users thanked this post: Zucca, neo
Offline neo
  • The specialist.
« Reply #4376 on: December 05, 2017, 09:12:11 am »
]I got a proper powered desoldering station so the tip melts the solder, give a little wiggle while squeezing the trigger to switch the vacuum pump on and the solder gets sucked up into a catchment chamber, easy peasy.
Sent from my SM-J510FN using Tapatalk
Same, i dont know how I did it before with solderwick! I must have been insane!
These days I frequently replace 64 pin 68000 sockets from battery damaged Amiga's and without the solder gun there's no way I could do it - I just dont have the time or patience now.
Even with solder wick i find it nigh impossible.
Metcal writ on the side wouldn't be bad.  :-DD
In all seriousness what's the magic term, i type in desoldering and get a whole lotta useless results sub $300.
Also, the only problem with the big one is the space it can fit in, and while on the topic of desoldering anyone got any tips for double sided boards? I can desolder single sided like a champ but double side has been a permanent vexation.
The answer is once again a proper desoldering station with or without Metcal written on the side, oh hang a minute, pass me that marker pen and I'll write it on for you if your so hung up a brand name.. :-DD
So then what is available cheaply that wont drive me batty?
 :-+ :-+ :-+ :-+ :-+ :-+ It is not the brand name i love it is the technology, i do things with my metcal i would otherwise need a 300 watt gun for.
EDIT: I heartily approve of the concept of god using metcal, though i believe he exists. Call it a character flaw or superstition if you like.
« Last Edit: December 05, 2017, 09:14:17 am by neo »
« Reply #4377 on: December 05, 2017, 09:13:30 am »
Here you go, look at these,
https://www.ebay.co.uk/itm/150W-Desoldering-Rework-Iron-Station-Digital-De-Soldering-Gun-Dual-LCD-UK/162332257199
https://www.ebay.co.uk/itm/Pro-Dual-LCD-Digital-2-in1-Soldering-Desoldering-Vacuum-Rework-Station-ZD-917/282698372391
http://www.ebay.co.uk/itm/Aoyue-474A-Desoldering-Station/232388501417
http://www.ebay.co.uk/itm/DURATOOL-D00672-DESOLDERING-STATION/142477115310
The last one is the same one that I've got, like I said it works a treat.
Offline djos
« Reply #4378 on: December 05, 2017, 09:15:19 am »
Sometimes us mere mortals need to work with what we can afford....
 :-DD
« Reply #4379 on: December 05, 2017, 09:16:41 am »
 :-DD
Exactly, I'd love to drive a Rolls Royce and not a Skoda...
Offline djos
« Reply #4380 on: December 05, 2017, 09:18:18 am »
I've got this very unit myself, I'd love a Weller (trained on them) but for fixing my mates gear and my other hobby needs I cant fault it.
« Reply #4381 on: December 05, 2017, 09:23:03 am »
Yep, apart from it being a dual tool, there is nothing wrong with this brand, they are well put together and almost identical to the one that Dave tested. I only have the single tool version, and looking at the price differences, this twin tool one is real bargain, snap one up today...
Offline djos
« Reply #4382 on: December 05, 2017, 09:26:13 am »
The best bit is spares are cheap and widely available - even our national electronics chain (Jaycar) rebrands this gear so if im in a bind (which is rare) I scoot down to my local store for tips or filters.
« Reply #4383 on: December 05, 2017, 09:42:07 am »
Everyone knows that size matters when it comes to equipment.
Nope. Not in that case.
I've bought this 2 years ago and it is the best desoldering pump I've ever had (Engineer SS-02):
https://www.ebay.com/itm/112648207623
« Last Edit: December 05, 2017, 09:43:45 am by BU508A »
Offline ChrisLX200
« Reply #4384 on: December 05, 2017, 11:20:29 am »
Those things are fine for some jobs (I have one) but they are a ball-ache when you have to desolder a centipede - and you can't wiggle the legs around in a circle while sucking to clear all the solder from through-hole parts so you end up prodding the thing with the soldering iron while pulling on it (bad). I'll stick with an electric vacuum gun I think.
« Reply #4385 on: December 05, 2017, 11:34:28 am »
You are right, and I prefer an electric vacuum gun as well. But sometimes I can't use it (e.g. I'm involved in a thing which is called "Repair Bar" and I can't take my whole equipement to this place), therefore this desoldering pump is my second choice after the electric vacuum desoldering tool.
« Reply #4386 on: December 05, 2017, 11:35:23 am »
1000% agree with you  :-+
« Reply #4387 on: December 05, 2017, 11:36:08 am »
I can't stand the vacuum desoldering pumps. I've had several and they make a right mess and chuck solder over everything.
I still think the best thing so far is, unless you're lifting one leg or something, snip the component out and use braid. Nice clean holes, no splatter. DIP? snip it out as well, solder a nice quality Harwin turned pin socket in at the same time (I have several tubes of them).
I'm going to be honest. I have got through the last 20 years with just braid so I'm going to stick with it for now :)
A roll of this lasts me about 3 months: https://uk.rs-online.com/web/p/desoldering-wicks-braids/7630709/
« Last Edit: December 05, 2017, 11:38:08 am by bd139 »
« Reply #4388 on: December 05, 2017, 11:45:29 am »
WTF!! How in the hell where you using it? All the ones I've seen leave no mess whatsoever and all the sucked up solder is retained in a small tank that needs to be emptied every now and then. I've never had any solder splattered all over the place at all?
« Reply #4389 on: December 05, 2017, 11:50:28 am »
It's the manual pump ones that do that. The vacuum pump driven ones are ok. The manual pump ones were banned when I did rework professionally. We used Weller DS801's which were pretty good (when they weren't clogged up!)
If you look carefully at a board after using a manual one for a bit, you will see lots of very tiny solder blobs over everything. They get into everything and cause trouble. The solder cools inside the nozzle and then when you re-arm it, they fall out before the thing has a chance to suck them back up again.
« Reply #4390 on: December 05, 2017, 12:26:19 pm »
Now that I can concur with, I have seen that many times and now I know why  :-DD
Offline ChrisLX200
« Reply #4391 on: December 05, 2017, 12:36:07 pm »
Not too happy with the spring solder catcher in the Aoyue 474A+ as it seems to be designed to never let go of it again. Only way of clearing it is to hold it with pliers and blast it with the hot air gun. Tried giving it a coat of silicone grease to stop it sticking but it made no difference, it's the shape of the thing. Other than that it's pretty effective.
« Reply #4392 on: December 05, 2017, 01:01:33 pm »
Yes that spring has a neck that is too narrow
« Reply #4393 on: December 05, 2017, 01:05:42 pm »
This thread is making me itchy for a new soldering iron now.
I love my Weller. It's near perfect but those Hakko 951's look nice (as much as I want one, I can't justify a Metcal iron)
Offline neo
  • The specialist.
« Reply #4394 on: December 05, 2017, 04:30:35 pm »
I got my base for 120 used, came with some tips and a hand-piece base, a new handp-iece doesn't fit exactly the same but only cost me 80 and new tips only cost me 20 a pop. The tips last longer than the hand-piece if used properly.
Offline Zucca
  • EE meid in Itali
« Reply #4395 on: December 05, 2017, 04:34:51 pm »
After I touched a Metcal I can't use anything else....  :-//
Online nfmax
« Reply #4396 on: December 05, 2017, 04:36:08 pm »
Well not until the burns heal, anyway!  ;)
The following users thanked this post: Mr. Scram
« Reply #4397 on: December 05, 2017, 04:38:28 pm »
Is the Metcal PS-900 any good? That's actually affordable (£216 from RS inc VAT)
Edit: cheaper on Rapid at £201 inc VAT
Edit 2: cheaper on Rapid via ebay at £185.39 inc VAT
« Last Edit: December 05, 2017, 04:43:36 pm by bd139 »
« Reply #4398 on: December 05, 2017, 04:42:00 pm »
Thats just rubbish, good they may be but to say you can't use anything else, come on., does it do the soldering for you? What would you do if Metcal stopped trading then, cease soldering would you???
Offline neo
  • The specialist.
« Reply #4399 on: December 05, 2017, 04:44:24 pm »
I don't personally own it but, it has smart heat the big reason to want metcal. Besides that it is metcal so if your buying it new you almost can't go wrong.
