Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 16664394 times)
zrq, URI, powerflux and 38 Guests are viewing this topic.
« Reply #4125 on: November 26, 2017, 08:06:18 pm »
« Reply #4126 on: November 26, 2017, 08:17:00 pm »
Thats a bit better, strange though that the Unimat 3 was introduced to replace the Unimat SL and the toy one that sent you was called Unimat 1, what happened to Unimat 2?
How would that help you do panel work?
Offline HalFET
« Reply #4127 on: November 26, 2017, 08:23:49 pm »
« Reply #4128 on: November 26, 2017, 08:26:46 pm »
Just saw this on eBay, must say I almost wandered over to "Buy Now": https://www.benl.ebay.be/itm/X-RAY-BALTOMATIC-AIS706-SCHLUMBERGER-BALTOBLOC-SPO-70-TV-POSTAL-PARCEL-SCREENING/321717619328  |O
Expecting something nasty to come your way then?
« Reply #4129 on: November 26, 2017, 08:31:35 pm »
Actually drilling the holes in a straight line ;)
« Reply #4130 on: November 26, 2017, 08:48:36 pm »
I'd better join you then, I've just managed to drill my binding posts 2mm out of alignment with each other, but at the end of the day, who cares, I don't it does a job of work for me and thats it.
Offline neo
  • The specialist.
« Reply #4131 on: November 26, 2017, 08:51:46 pm »
I like to think that I do pretty decent panel work with exceedingly simple tools, a hand drill, hacksaw blade (just the blade), a reamer and file. Sometimes a hole saw if neatness or speed is required.
Of course just for projects.
« Reply #4132 on: November 26, 2017, 08:54:18 pm »
Clearly I don't have your patience, I just want to get to the stage where I'm either using it or testing it and if I can take a short cut I will  :popcorn:
Offline tautech
« Reply #4133 on: November 26, 2017, 08:54:36 pm »
We were taught at high school to use metal scribers when doing final mark outs as the line they leave better helps a pin punch to keep on position. Then the mark should be improved with a centre punch the better keep the drill bit from wandering. Punches need be kept needle sharp for precise marking.
« Reply #4134 on: November 26, 2017, 08:55:59 pm »
Very true but then I'm working with ABS  :-DD
Offline tautech
« Reply #4135 on: November 26, 2017, 08:58:22 pm »
Sharp tools are still needed.  :P
Offline neo
  • The specialist.
« Reply #4136 on: November 26, 2017, 08:59:02 pm »
It's as much a matter of patience as it is preference of allocating funds to TEA. Perhaps a bit of apathy towards the looks, i take a stance of it don't have to look pretty to work good.
« Reply #4137 on: November 26, 2017, 09:03:56 pm »
Exactly, its only for my use so it don't have to look particularly pretty, its more about functionality to me. I can do nice panel work if I have to, I used to produce motor control panels at time that were used as part of an automated assembly line making small arms for the British Army, so it had to be nice because it was on show.
The following users thanked this post: neo
Offline HalFET
« Reply #4138 on: November 26, 2017, 09:23:21 pm »
You could easily convert this unit for board inspection.
Offline ChrisLX200
« Reply #4139 on: November 26, 2017, 10:37:54 pm »
If you can afford the workspace buy a larger lather - 3-1/2" CH at least. You would discover the limitations of a Unimat rather quickly I think.
« Reply #4140 on: November 27, 2017, 02:17:09 am »
Well, since I didn't find anything of interest on Black Friday, I happened to take a look at eBay (no surprise, right?) and saw a DE-5000 with the alligator clips, tweezer, and guard accessories for $80 including shipping. So, I clicked it. (Again, no surprise, right?)
Now, I'm just hoping it's legit.
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #4141 on: November 27, 2017, 02:32:50 am »
Surprise! (not  :-DD)
Nice piece of kit. Let us know the degree of legititedness of your find.  :popcorn:
« Reply #4142 on: November 27, 2017, 02:58:31 am »
Yep, I'll compare its measurements to an Agilent U1732B. :-+ I think there are also teardown photos of the DE-5000 around here.
Offline Vtile
  • Ingineer
« Reply #4143 on: November 27, 2017, 02:24:19 pm »
Bit bigger: http://www.lathes.co.uk/emco/page3.html
Ok it were a big mistake to open this thread again.  |O
Offline iainwhite
  • Measure twice...
« Reply #4144 on: November 27, 2017, 03:11:30 pm »
I am hoping to pick up a South Bend 9" lathe in the next few weeks, if negotiations go well...  Fingers crossed.
Offline ChrisLX200
« Reply #4145 on: November 27, 2017, 03:26:49 pm »
Quote from: iainwhite on Today at 02:11:30 AM>Quote from: ChrisLX200 on Yesterday at 09:37:54 AM
Nice lathe - solid, dependable. :)  Still need tooling though unless you can get it thrown in with the purchase price. I spend more time making tools than anything else really, though electronics has moved to the forefront recently. Pictured are a couple of precision knurling tools I designed/made recently for my Myford lathe.
Offline tautech
« Reply #4146 on: November 27, 2017, 03:33:34 pm »
Very nice job Chris.
Harrison 12 owner here.  :)
Just after I got her home 3 and a bit years back.
« Last Edit: November 27, 2017, 03:35:32 pm by tautech »
The following users thanked this post: iainwhite, ChrisLX200
Offline iainwhite
  • Measure twice...
« Reply #4147 on: November 27, 2017, 03:38:11 pm »
I am hoping to get tooling etc. as a package. That is the 'negotiation' bit.   It was pure luck - a friend of my wife is clearing her father's house and asked me to help her to value "the stuff in the basement".  He was a machinist, and the basement is an Aladdin's cave of tools & gear - including 3 lathes!
I think your knurling attachment is beautiful work - I hope I can do that well.
The following users thanked this post: ChrisLX200
« Reply #4148 on: November 27, 2017, 03:44:29 pm »
I set the lathe heads off again  :-DD
Offline tautech
« Reply #4149 on: November 27, 2017, 03:48:43 pm »
Machine tools are as addictive as test equipment.  :-+
We need help too.
