Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 18103368 times)
dxl, Jambalaya, TSCOLAN and 45 Guests are viewing this topic.
Offline tggzzz
« Reply #1850 on: August 01, 2017, 07:35:24 am »
Out of curiosity does anybody have a reason for 6.5 digit multimeters costing so much?
5.5 digit used fluke is a 100 bucks or under
6.5 digit used fluke is a 1000 bucks or over
8.5 digit used fluke, the only one on ebay is used and is 16 grand!!
Is there a reason for such madness?
Maybe I was lucky and/or patient. Datron 1061 for £30 delivered, Solartron 7081 for <£100, but I've had to fettle with them and they aren't calibrated. The latter, or my £11 Trancell voltage source, read 35ppm off 10V.
Have you seen the price of a calibration, let alone an adjustment?
Offline neo
  • The specialist.
« Reply #1851 on: August 01, 2017, 11:28:50 am »
Fair enough, though a multimeter at 16000 still strikes me as insane. We need a time machine to either go back to when this stuff was cheap or forward to when it will be cheap...
8.5-digit multimeters aren't easy to make or there'd be lots of them. Going back probably wouldn't help since in the old days, things we take for granted were expensive back then. Perhaps going forward yields potential for picking up today's expensive kit for less. However, if you couldn't come back, then you might want the then-available-but-too-expensive 10.5-digit multimeters. :-DD
GAS and DBA transcend space and time.
If we went back 15 years, nixie kit would be slightly cheaper on ebay, and if we were to go forward by the same amount modern kit should in theory be rendered cheaper as well. In theory, of course you have a point, we would then want the newest 10.5 digit multimeters so we could compulsively start going forward in time until we became completely lost,  then there is the problem of only organic matter being transferable through wormholes so the future would probably be off limits unless you were to hide it and wait. Same goes for the past only in the past you can hide it and then when you come back it is instantly available.
Of course there is also causality to contend with, if you were to start buying nixies back in 2000 then you may well spark the nixie fashion trend many years too soon and render them extinct.
Also as a side note, causality still comes into play with the future because how could one go forward to THE future when there isn't just one future? Every choice made now has a butterfly effect so the future you went to and hid test equipment in would have no guarantee of being the future you would get. Therefore any test equipment you hid probably wouldn't be there when you came back for it all those many years down the line.
I have put alot of thought into time travel does it show?
« Last Edit: August 01, 2017, 11:30:54 am by neo »
« Reply #1852 on: August 03, 2017, 05:22:58 am »
Yes, that's more than I dared to quote or it might disrupt the space-time continuum. ;D
The following users thanked this post: neo
Offline neo
  • The specialist.
« Reply #1853 on: August 03, 2017, 03:03:23 pm »
There is only one solution, an infinite probability drive. Of course we may all become a sofa if we used that, but what little cost that is to pay for nixie tubes!
Offline neo
  • The specialist.
« Reply #1854 on: August 03, 2017, 07:30:18 pm »
A fluke 8800A that i just won on bidding, cheap too at only $40 half of that for shipping.
You won it!  Sweet!   :-+ :-+
Congrats!  Sounds like you got a good deal on it, too.  Glad to hear, and look forward to seeing some Fluke 8800A pron once you receive it.
-Pat
Well for once 3 multimeters got into a room and two of them agreed, the 5.5 digit insisted it was .00003 lower than the other 2 said. It should be noted that my Instek GDM-8034 is in calibration, so therefore all my other meters are as well because they all are congruent.
Only two gripes and they are both very minor, the handle broke in shipping and it is missing a rubber foot.
Also, the quote is from another thread but was relevant.
Edit to add picture and addendum.
As i said, all accurate to the instek, which is in cal, and all are dead on to it give or take .003 volts and to entirely objective this measuring the output of a power supply that isn't particularly stable in the thousandths of a volt.
« Last Edit: August 03, 2017, 08:21:03 pm by neo »
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #1855 on: August 03, 2017, 08:17:51 pm »
Well, if you round up they all agree!!
-Pat
Offline neo
  • The specialist.
« Reply #1856 on: August 03, 2017, 08:22:04 pm »
-Pat
I wonder, do you think i broke the world by getting 3 multimeters congruent?
« Last Edit: August 03, 2017, 08:26:51 pm by neo »
Offline Cubdriver
  • Nixie addict
« Reply #1857 on: August 03, 2017, 08:25:14 pm »
-Pat
I wonder, do you think i broke the world by getting 3 multimeters that congruent?
Probably not - I haven't felt any noticeable rotational shifts.  Get another and try for four!!!   >:D >:D
-Pat
<edit to add - I hadn't yet seen the pic with the five of them in it!>
Offline neo
  • The specialist.
« Reply #1858 on: August 03, 2017, 08:34:44 pm »
-Pat
-Pat
 :-DD The really funny bit is if i sit there and watch them they will agree shortly, just not long enough to get a picture in. Not only are there 5 in the second picture but those 5 are all the multimeters i own.
« Last Edit: August 03, 2017, 08:53:58 pm by neo »
Offline VK5RC
« Reply #1859 on: August 03, 2017, 09:18:11 pm »
There is a name for trying to get those digits all to agree - volt-nuttery!
Offline neo
  • The specialist.
« Reply #1860 on: August 03, 2017, 09:20:10 pm »
 ::) i DEFINITELY have that! As well as a pretty collection of meters, all (excluding instek) will tend to agree it is the insteak that just has to be .3% different.
« Last Edit: August 03, 2017, 09:22:03 pm by neo »
Offline tggzzz
« Reply #1861 on: August 03, 2017, 10:59:35 pm »
No, it doesn't mean that.
But it does mean you need multimeters with more digits.
Online Fungus
« Reply #1862 on: August 03, 2017, 11:01:12 pm »
it does mean you need more digits on the multimeters.
This.
If your meters are in agreement it's only because you don't have enough digits.
Offline neo
  • The specialist.
« Reply #1863 on: August 04, 2017, 12:01:41 am »
Well i can't afford a 6.5 or 7.5 and i certainly cannot afford an 8.5 so by all means feel free to give them to me. I'll give excellent pictures of them in exchange.
Offline Zucca
  • EE meid in Itali
« Reply #1864 on: August 04, 2017, 08:06:30 am »
DO LOOP
My brain:"that´s so cheap, not sure where to use it right now, but it is soo cheap. You never know what the future looks like."
My hand just clicks on "Buy now".
Two years later...
My brain: "What is this box here?"
My hands open the box.
My brain: "Ahhh, it was so cheap... not sure how much I paid for that.. mmm Let's sell it on the EEVBLOG"
END LOOP
Offline neo
  • The specialist.
« Reply #1865 on: August 04, 2017, 01:19:29 pm »
-Pat
The handle was fixed with super glue and the foot was replaced with duct tape.
Offline alm
« Reply #1866 on: August 04, 2017, 01:35:24 pm »
How do you replace a rubber foot with duct tape? Tape the meter to the shelf?
Offline neo
  • The specialist.
« Reply #1867 on: August 04, 2017, 02:07:08 pm »
Wad the duct tape up to size and then tape it on. When wadded enough to resemble a foot it becomes as rigid as rubber and thus makes it sit the way it is meant to and not wobble. It works quite well.
« Last Edit: August 04, 2017, 02:12:47 pm by neo »
« Reply #1868 on: August 04, 2017, 02:14:36 pm »
Duct tape feet. Too many Flukes. Nixie tubes. I think I need to join this thread :)
Offline neo
  • The specialist.
« Reply #1869 on: August 04, 2017, 02:17:23 pm »
Welcome to the hotel California, you can checkout anytime you like but you can never leave!
« Reply #1870 on: August 04, 2017, 08:58:19 pm »
Duck-footed test equipment. Brilliant.
Welcome, bd139. I concur with your thinking.
Offline Vtile
  • Ingineer
« Reply #1871 on: August 04, 2017, 11:13:01 pm »
Hmmpf.. I have been looking a decent autotransformer for a long time. Always slips through my nose in auctions or the unit or seller itself is somehow dodgy. Well I did pull the tricker a few weeks ago and bought a new 3 amp IP00 unit and yesterday I finally got around to start to build a casing to it. Today I started to bolt the internals to it.
..And then I noticed a one dealer of addictive substances (TE) were selling 2.5kW autotransformer for less what I paid for this 700W unit. There were also nice laboratory potentiometers in 500W plus size, uh.. And one lady who doesn't know what she is selling is trying to get rid of nice looking Goertz (GOSSEN METRAWATT) Unigor 6e, I think I need a spare unit?  :palm:
Offline WastelandTek
I'm new here, but I tend to be pretty gregarious, so if I'm out of my lane please call me out.
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #1874 on: August 05, 2017, 01:39:43 am »
...and then you join this thread. :-DD
