Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17687576 times)
diskcopy, Vince and 27 Guests are viewing this topic.
Offline neo
  • The specialist.
« Reply #1825 on: July 30, 2017, 02:24:13 am »
Just to tempt you all here is version one of a list of 8000 series flukes, i am undoubtedly missing dozens so feel free to add to it and pass it along.   :popcorn:
^ = want
*  = currently own
« Last Edit: July 30, 2017, 04:06:10 am by neo »
Offline Tony_G
  • Checkout my old test gear channel (link in sig)
    • TGSoapbox
« Reply #1826 on: July 30, 2017, 11:06:54 am »
Just got back from vacation and realized that, yes I have a problem. Here is the lab as it greeted me:
I think it was the stark contrast with the tidy hotel rooms that brought my problem into focus.
Clearly I need help but not right now because I have to just complete this auction purchase, be right back.....
TonyG
Offline Tomorokoshi
« Reply #1827 on: July 30, 2017, 11:19:56 am »
TonyG
I don't get what the problem is. You still have space on the floor next to the HP 432A.
Offline HighVoltage
« Reply #1828 on: July 30, 2017, 11:33:44 am »
And you can always add another room to the lab, to have more space
And plenty of space to set up shelfs. And these shelfs can also be found on ebay.
Offline neo
  • The specialist.
« Reply #1829 on: July 30, 2017, 02:46:19 pm »
Out of curiosity does anybody have a reason for 6.5 digit multimeters costing so much?
5.5 digit used fluke is a 100 bucks or under
6.5 digit used fluke is a 1000 bucks or over
8.5 digit used fluke, the only one on ebay is used and is 16 grand!!
Is there a reason for such madness?
Offline alm
« Reply #1830 on: July 30, 2017, 03:30:44 pm »
With Fluke it is largely age: they introduced the 8840/8842 5.5 digit meters sometime in the late eighties, then nothing apart from the Fluke 45 for a long time, and they bought Datron and introduced the 8508 (8.5 digit) and 8846 (6.5) digit. So obviously the 8846 is much more expensive used than an 8840, 8810 or 8800.
If you look at the older Fluke 6.5 digit meters like 8502A, 8505A, 8506A, they can also be found for around the $100 mark depending on condition and options. Keep in mind that almost everything on those meters was optional except DCV, so you might end up with a meter that can measure nothing but DCV. There are also 6.5 digit meters of similar vintage from other brands like HP (3455a, 3456a, 3457a), Datron (106x/107x), Solartron, Prema and Keithley (196) that are available for well under $1000. I have not kept track of pricing, but a number of years ago it was common for the HP 3456A/3457A to go for about $100 in decent condition. Even the more recent HP/Agilent 34401A and Keithley 2000 can be found for around $250 if you are patient.
So if anything, I would say that there is not much price difference between 5.5 digit and 6.5 digit of similar vintage. More than 6.5 digit gets expensive because there are is less competition, but some 7.5 digit models like Datron 108x and Keithley 2001 can be found for under $1000.
Offline neo
  • The specialist.
« Reply #1831 on: July 30, 2017, 03:36:16 pm »
Fair enough, though a multimeter at 16000 still strikes me as insane. We need a time machine to either go back to when this stuff was cheap or forward to when it will be cheap...
« Last Edit: July 30, 2017, 03:38:27 pm by neo »
Offline German_EE
« Reply #1832 on: July 30, 2017, 03:49:03 pm »
TEA Group members, I now have a problem. Connecting both of my frequency counters to my new (new to me) Wavetek function generator I get the following readings with the dial at 1 MHz:
Portable frequency counter      1.0013126 MHz
New Philips counter                  1.0013103 MHz
Clearly there is a difference between the two but I am not sure which counter is in error. Should I send the Philips counter away for calibration or purchase a third counter to see which unit is correct?
Or should I reassemble my DCF77 locked 10 MHz reference which is currently in pieces awaiting a new VCO?
Warren Buffett
Offline neo
  • The specialist.
« Reply #1833 on: July 30, 2017, 04:13:23 pm »
Well since this is TEA we advise buying as much stuff as you possibly can.
The following users thanked this post: tablatronix
Offline jpb
« Reply #1834 on: July 30, 2017, 04:17:58 pm »
Given that this thread is under TEA, I'd suggest buying a third counter :)
But with a more sensible hat on, I'd suggest just getting a cheap GPS and measuring its output over a longish period to get rid of the jitter. You can get cheap Lea-6T on e-bay as per this thread:
https://www.eevblog.com/forum/projects/ebay-u-blox-lea-6t-gps-module-teardown-and-initial-test/
Offline WastelandTek
« Reply #1835 on: July 30, 2017, 04:31:48 pm »
Hey guys, serious question, what do y'all think of the HP 3312A function generator?
I'm new here, but I tend to be pretty gregarious, so if I'm out of my lane please call me out.
Offline neo
  • The specialist.
« Reply #1836 on: July 30, 2017, 04:41:32 pm »
It needs more nixie tubes!  :-DD
Seriously though it has a nice frequency range, and the rest of its specs look nice, though i don't know anything about it, or what your purpose is, so my opinion stops dead there before i embarrass myself.
Offline alm
« Reply #1837 on: July 30, 2017, 05:15:31 pm »
What oscillators are they using? I expect the portable one to use a TCXO at best. 2.3 ppm does not strike me as excessive for a standard XO or even a TCXO after a couple of years. So it may very well be that both are in spec (or out of spec). If you want to be sure, I would send the one with the most stable oscillator out for calibration (or adjust it to a GPSDO).
Online tggzzz
« Reply #1838 on: July 30, 2017, 05:47:21 pm »
Oh dear. On Thursday an ESI Dekapot KVD turned up, as expected.
Today I went to a geek car boot sale - and sold a few things I'm pleased to say. But I found another ESI Dekathingy at a price I couldn't resist.
As you can see, each decade range has 11 positions (0-10), so I can claim it goes all the way up to 11. Or more accurately, this Dekastat goes up to 121.1ohms.
At first I thought the 0.01ohm step range was buggered, but then I improved my measurement technique and it is just fine.
Offline mtdoc
« Reply #1839 on: July 30, 2017, 06:04:46 pm »
They're nice FGs when working.  I have one that I got for cheap on the bay and it worked for a while... Now it sits in my repair queue (at the back I'm afraid).
Some nice pics in this thread
« Reply #1840 on: July 30, 2017, 06:27:12 pm »
These are simply the pinnacle of analogue function generators and were pretty much a "nothing is too expensive" job by HP.
Thanks, that clears matters up...now I have a decision to make
https://seattle.craigslist.org/see/ele/d/tektronix-oscilloscope-with/6241145888.html
Offline mtdoc
« Reply #1841 on: July 30, 2017, 06:54:50 pm »
Offline German_EE
« Reply #1842 on: July 30, 2017, 08:35:39 pm »
Take it, the function generator is a lot better than the one I have and HP scopes are nice.
As for the post by alm, the portable counter has a TXCO in it that I retrofitted a few years ago. I'm not a volt nut but I am fast becoming a frequency nut and any error greater than 1 Hz is treated as a major disaster.
Warren Buffett
« Reply #1843 on: July 30, 2017, 08:46:42 pm »
Nice vintage combo!  :-+
"vintage" lol
that would be the newest scope in the house by a bit
maybe I should just keep saving for the Rigol...lol
Offline Carl_Smith
    • MegaMicroWatt - Carl Smith's Blog
« Reply #1844 on: July 31, 2017, 12:11:48 am »
Clearly there is a difference between the two but I am not sure which counter is in error. Should I send the Philips counter away for calibration or purchase a third counter to see which unit is correct? Or should I reassemble my DCF77 locked 10 MHz reference which is currently in pieces awaiting a new VCO?
All of the above, obviously.    >:D
Online tggzzz
« Reply #1845 on: July 31, 2017, 12:59:05 am »
Take them to https://www.eevblog.com/forum/metrology/ptb-at-the-maker-faire-in-hannover/msg1268287/#top
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #1846 on: July 31, 2017, 08:07:36 pm »
Problem?
Mhm.. no problems..
Just another never ending project.  :phew: :palm:
Offline buck converter
« Reply #1847 on: July 31, 2017, 08:34:06 pm »
So Today at a highschool STEM camp at a college, my friend said, "look a dumpster full of computers!" reminding myself that I don't need more computers ;), i go in the hallway to check it out. They were not computers, they were HP and Tektronix analog oscilloscopes. There were atleast 15 :). the looked good, some had power cords, the BNCs were tight.
I was not hungry to take the scopes because I am addicted to old stuff or because I need one, rather because I knew I could sell them to raise money for my High school's robotics team, which desperately needs money :-\. This past year, we could not afford a Laptop to program the robot. I got this idea when browsing eBay for an oscilloscope, a seller said it was for his robotics team, I know how desperate his club could be.
I had to ask the instuctor if they are being chucked, for a few reasons: The dumpster was indoors; there was a note that said "to centeral Islip, room 203". After telling him about my robotics club, he agreed to find out if I could take some. I will not find out until Monday. If i do get some, I will sell some on eBay to raise money for my robotics team, and I will sell some at a low price on this forum to begginers like me, who learned so much from these tools.
I spoke to the robotics instructor today, he said we could figure something out! :-+
Just me and my scope.
« Reply #1848 on: August 01, 2017, 12:45:25 am »
That's great news, buck. Hope it does work out.
« Reply #1849 on: August 01, 2017, 12:50:02 am »
8.5-digit multimeters aren't easy to make or there'd be lots of them. Going back probably wouldn't help since in the old days, things we take for granted were expensive back then. Perhaps going forward yields potential for picking up today's expensive kit for less. However, if you couldn't come back, then you might want the then-available-but-too-expensive 10.5-digit multimeters. :-DD
GAS and DBA transcend space and time.
