Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 18797360 times)
salvagedcircuitry and 52 Guests are viewing this topic.
Offline PA0PBZ
« Reply #1700 on: July 07, 2017, 05:19:57 pm »
double dose
Since they don't agree you need at least a third one!
Offline alm
« Reply #1701 on: July 07, 2017, 05:20:40 pm »
Interesting way to do 2-wire resistance measurements. Though it is obvious and trivial, so I would expect it to be used on some early DMMs, I do not think I have seen a DMM that can not do 2-wire resistance measurements without external shorting links.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #1702 on: July 07, 2017, 05:39:07 pm »
double dose
Here's a third.  (though it doesn't help much as it doesn't agree either...   :-// )
-Pat
Offline PA0PBZ
« Reply #1703 on: July 07, 2017, 05:44:06 pm »
Never mind, I fixed it for him already :)
Offline Gyro
« Reply #1704 on: July 07, 2017, 05:52:10 pm »
Uh oh - I just purchased my first Nixie tube test equipment. I've been on the lookout for a reasonably priced, good condition and small Nixie tube counter. Not because I need a counter - I have a perfectly functional Tek CM251 - but because Nixie tube counters look cool.  Is that so wrong? Am I in danger od succumbing to Nixie Tube Derangement Disorder?
Welcome to the orange glowie side.
Neither forget nor neglect the other orange glowie displays: Panaplex.
They are remarkably soothing and restful to watch. Every home should have some.
I can't disagree with you there!  :D
Best Regards, Chris
Offline guido
« Reply #1705 on: July 07, 2017, 09:46:38 pm »
LOL
We can dream, right?
 :P
Offline WastelandTek
I'm new here, but I tend to be pretty gregarious, so if I'm out of my lane please call me out.
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #1707 on: July 08, 2017, 11:47:12 am »
hmmmmm
http://www.ebay.com/itm/Tektronix-R7844-Mainframe-Oscilloscope-for-Parts-or-Repair-7844-Rack-Mount-/192231525261?epid=96937705&hash=item2cc1e44b8d:g:TdwAAOSwOMdZVD8C
what do you guys think?
Well -
For parts or not working
“Blows fuses immediately on power up. Missing knob and CRT surround. No accessories or plug ins ”
I'd say it's just about perfect for a TEA member.  :-/O
Offline neo
  • The specialist.
« Reply #1708 on: July 08, 2017, 07:34:16 pm »
As far as my TEA addiction goes i think i may now be well beyond any hope of recovery. I fixed my first old electronic. Comically it was because it didn't like a capacitor that it broke.
« Reply #1709 on: July 09, 2017, 07:14:22 am »
Ooh, lots of glowing displays! You can never have too many of those, surely.
Meanwhile, I put up a thread for the HP 3469A that I showed a preview of in this thread a little while ago. Enjoy!
https://www.eevblog.com/forum/testgear/hp-3469a-multimeter-70's-vintage-teardown-and-clean-up/
Offline Brumby
« Reply #1710 on: July 09, 2017, 07:36:51 am »
A classic exhortation of a soul lost to TEA!!
I am jealous.
« Reply #1711 on: July 09, 2017, 07:38:20 am »
Anytime is TEA time. ;D
Offline denimdragon
  • "Hole charge chaser and wanna-be o-scope fixer"
« Reply #1712 on: July 11, 2017, 04:10:09 am »
 I've finally come to grips with reality...  I can't stop testing, measuring, and auction/ebaying and I'm still in my first year of school :palm:
"Hi there. I'm short in the hair department, do you mind if I pull a few strands from your head? Thanks!"
Offline neo
  • The specialist.
« Reply #1713 on: July 11, 2017, 04:31:49 am »
How much equipment/stuff in general do you have?
Offline Berni
  • Country: si
« Reply #1714 on: July 11, 2017, 05:13:26 am »
The answer to that is always: "Not enough"
Offline neo
  • The specialist.
« Reply #1715 on: July 11, 2017, 05:29:36 am »
Of course i just wanted to know for reference.
Offline Muxr
« Reply #1716 on: July 11, 2017, 06:40:14 am »
I used to only worry about test gear, since I've been inflicted with the voltnut bug it's also the expensive components now too  ;D $30+ foil resistors, $60 buried zeners and such. I think I also have like 4 different PCB designs in flight at Oshpark.
Offline orin
« Reply #1717 on: July 12, 2017, 04:52:53 am »
The real question is how many pieces of test equipment should you have, for which the answer is:
N + 1
where N is the number of pieces of test equipment you already have.
This is subject to the S - 1 rule which states that you are allowed S - 1 pieces of test equipment
where S is the number of pieces of test equipment at which your spouse/SO leaves you.  There are some that define S - 1 as the number of pieces of visible test equipment, but that is an extremely risky proposition...
Offline neo
  • The specialist.
« Reply #1718 on: July 12, 2017, 05:20:51 am »
N + 1
There is also NX+* which means whatever the number of NX is it needs more added to it, NX being nixie tubes.
Offline orin
« Reply #1719 on: July 12, 2017, 06:09:18 am »
N + 1
Definitely, since my NX is zero...
Offline Berni
  • Country: si
« Reply #1720 on: July 12, 2017, 07:45:05 am »
Zero here too, but i did order a interesting old russian nixie matrix display. Impressive resolution too at 100x100 pixels!
Offline BravoV
  • +++ ATH1
« Reply #1721 on: July 12, 2017, 08:01:31 am »
Freshly acquired at local recycler shop, two vintage meters for $15.
Both are considered damaged by the seller, also as I couldn't test it on site too, since the Fluke's LCD is clearly gone, and the Simpson 260 uses the damn reverse banana plugs that I don't have nor the seller.
Even both are beyond repair, not bad as vintage T&M ornaments, right ? >:D
Physically both are still pretty decent, but I haven't open them up yet, wish me luck especially for the Simpson.
Offline alm
« Reply #1722 on: July 12, 2017, 08:59:24 am »
Depending on the depth, you might be able to use the Simpson meter with female-to-female safety banana lead couplers that are somewhat common and are part of some test lead sets.
« Last Edit: July 12, 2017, 09:43:38 am by alm »
Offline neo
  • The specialist.
« Reply #1723 on: July 12, 2017, 09:41:44 am »
Sounds interesting, think you could put some pictures up when it gets to you?
Nice find, i have a particular affinity to Simpson made instruments, and based off the one i own they have their quirks. Like for example using a custom made connector only really available with the purchase of the instrument as an output terminal.
« Last Edit: July 12, 2017, 09:44:38 am by neo »
Offline BravoV
  • +++ ATH1
« Reply #1724 on: July 13, 2017, 12:27:38 am »
Yep, thats the plan, its just I don't have any with me, going to buy few of them.
This is my very 1st analog multi-meter, all mine are digital, planning to do full overhaul and restoration work on it, hopefully nothing seriously damaged inside, especially the moving coil.  :'(
