Think that's probably overkill for my requirements to be honest although I would love one.
I genuinely need to get rid of some stuff now if I'm honest and focus on some design projects rather than repair/purchase ones as well
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
And alas an HP6236B equivalent just appeared like magic after I posted that so here we go again for a reasonable £125...
![](http://i.imgur.com/I58Aqx3.png)
I have agreed withe other half to sell another supply, probably the shitty Heathkit one.
These are actually very nice supplies. I scored two of them on the cheep (I think 75 USD each) and i was quite impressed with them. I liked them so much intact that i went and bought another 2 from the same guy since he still had a few. Two out of the bunch did need the LED display board glued back in so it would sit right, because the tiny tab that holds it snapped in shipping. The plastic on the front panel does get quite brittle with age (So be very gentle on the front clips when taking the cover off)
Also i found that you can make the LED display update as fast as you want by replacing a single ceramic capacitor used as part of a RC oscillator. I set the update rate to about 10 Hz and that made it a joy to set the voltage. You could make it update faster than 30Hz if you wanted but i don't like the numbers becoming a blur, yet the meter still stays bang on to the last digit verified to my good bench meter.
If you are looking for a good quality simple analog PSU these things are what you want to look for. My only complaint with them is that they are a bit low power but they still cover most use cases just fine.
Thanks for the tips. Appreciated. This is exactly what I bought it for.
My requirements are pretty modest as most things I build with the supplies I have are just subcircuits of larger systems. The final devices always have their own power supplies or a switch mode wall wart. For example the long running "build my own scope" project has a homebrew royer converter which runs off 9-15v and delivers +/-15v, 6.3v and two 300v windings. That is what I need the bigger supply to develop.
I've got a Heath triple supply which is equivalent to the Agilent one really but it has analogue metering and some parts in it I don't fancy finding replacements for if it goes phut (which it has before). The thing also has no protection or consideration for the user either
TBH the main uses cases will be testing dual rail op amp and transistor circuits and providing 3.3 and 5v logic supplies which it is pretty good for.
Edit: I notice farnell are still selling these for £490 ex / £588 inc so that wasn't a bad deal:
http://uk.farnell.com/keysight-technologies/e3630a/power-supply-3ch-20v-2-5a-fixed/dp/1214486Would not have paid that for it new.
