You guys are sick , there is not such thing as too much test gear , just not enough space
My problem is not being able to go back in time , all the stuff [ if I new better ] that I didn't keep .
Surplus stores I bought military test gear just for the Zero Haliburton aluminum cases , all the stuff inside was through away - bad collector , bad collector .
Then yrs. late as the surplus places closed , I disposed of truck loads of gear , again before I new what to keep , doggy dew .
Now collecting Rubbermaid lawn sheds to process & store .
When I get enough pounds of products with gold , silver etc. - then use the funds to repair , collect more ....
HP 8640B combining to have at least one with all options , almost finished .
IFR A7550 only missing one option - the quasi peak detector .
Lots of other gear to repair & use .
Each time I get more and not enough space , the list get reavaluated and some goes to the recycling side of things , the other day another scope 20mhz working could not give away at club meeting , there was a 100mhz there also , I should have taken home
