This got all mixed up due to me trying to finish it in the car on my tablet, so I'm gonna make it a new post here. Oi. Ughhh... Pioneer is killing me. First, the whole gawddamn thing is cheapest possible single-sided paxolin PCBs with edge connectors stacked together like a gingerbread house; I spent a whole afternoon dismantling, inspecting and reassembling the stoopit thing to eliminate that very obvious point of failure. And yes, all rigid assembly; not even sense enough to use FPC interconnects because they'd cost 50c more per unit.
mode on:I swear, for the last 20 years, Pioneer just goes from one colossally shite design flaw to the next. Anybody here remember the wind-tunnel of doom with all the power semis in a PCB box that would go critical meltdown when the fan croaked or even slowed down due to dry bushings? This design may be worse... and it's not like they didn't know it is a major fault mode; checking all the PCB connectors is literally the first step in their diag process.
mode off:Anyways... Now that assache is done and eliminated as a culprit, I've traced out the STBY switch and relay all the way back to the CPU, and while it does pull the correct pin LO when I press the button, no signal from the CPU on the relay pin even after confirming all Vccs, AVccs and reference voltages present. I checked for the obvious pitfalls; no WAIT or RESET pin being held LO (as per the chip datasheet), but I did discover no oscillator at X201.
Suspecting a fauty crystal, I swapped it into an old USB-ASP I had lying around, and it came up with a nice clean signal right at 16mhz & 500mv p-p. I then tried replacing those two 22puff caps in the oscillator; but all I have on hand is 1puff and 100puff SMDs. I tried with the 1puff caps and it would oscillate for aboot 4 seconds every power-up; good clean signal just like above with the USB-ASP.
After that, I spent an afternoon harvesting random MLCCs from several PCBs; I gave that
BELKIN infested-with-spyware-from-the-factory NAS main board the ignominious demise it so justly deserves.
Sadly, I did not find a single 22puff cap after a good 2 hours sorting with my MS8911; everything I found (even teeny tiny little 0402 bastards) was either way higher or way lower value. Out of frustration, I tried it with the caps removed altogether, and now it does oscillate for a good 30 seconds at a time, but the waveform is a bit distorted due to the DC bias across the crystal, tho it is stable at a solid 16Mhz and again, 500mv p-p. Still no reaction to pulling the STBY switch input pin LO, though.
This did give an opportunity to do some further diag, however... And even tho I can see it oscillating at X201, I can't find any signal at any of the clock output pins.
*sigh*Right now I'm trying to lay my hands on a proper 0602 cap sample book at a sane price somewhere reasonably quick delivery; I really need it in my stockpiles anyways. Given the lack of any heartbeat 💓 from any pin on the CPU I have little hope of it bringing the thing back to life, but hey; it at least gives me something else to think aboot for a while.
