I'm going to do the unthinkable and compare two tektronix oscilloscopes.
7704A, with the right plug-ins is a full 4 channel 200Mhz scope without volatile cal data and overly complicated engineering.
2465B, The interface is quicker to navigate though it only has 2 full channels with 3 and 4 being limited. Besides that it NEEDS it's fan otherwise it WILL go
as if that wasn't enough it's entire calibration is stored in volatile memory. Then there are the small details such as the lack of sockets on the aforementioned volatile memory.....
Then again it isn't technically volatile but to me if it needs a battery to store data it's volatile.
Conclusion;
They both represent the best of tektronix, though the 2465B also represents why tektronix didn't do great when it came to the digital era. It seems to me that the main competing factor between tektronix 24xx and the mainframe is that it's smaller.
I may be speaking outta my ass but this is what i've observed thus far.
The reason they're so highly regarded is not only the art and craftsmanship, but also the depth to which they are documented for service, which is very nearly to the molecular level.
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
While battery-operated NVRAM sounds like a horrible idea, remember their design life was ~10 years, yet there are 30 year-old units STILL WORKING.
I believe I read in one of the threads I linked to that there was a problem with how the NVRAM was addressed that made most substitutes that had been tried unsuitable; IIRC, one pin that was usually pulled high every time a memory location was read, as opposed to the DS1225 which only pulled that pin high once for the entire read cycle.
And yes, finally... their great value (aside from being a 1GHz-capable portable scope way back when) was the fact of having all that power, and some really powerful setup capabilities in a single unitized device as opposed to having to have a flupping rack on wheels and procure/maintain/swap out plug-ins.
I have no idea on reading/programming the NVRAM; see above, and remember that I don't have a B. I only have a few lowly 2465s.
There is a fellow on eBay who's developed quite a reputation for knowing his stuff on Tek 'scopes, and for having the hard-to-find bits;
his nick is 2465b and I believe he's on eevblog under another nick.
Cheers,
*Toddling off to ded*
