Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17686171 times)
Robert763, onsokumaru and 29 Guests are viewing this topic.
« Reply #8350 on: March 08, 2018, 08:29:22 pm »
... instead used one of the most corrosive things she could have used, salt, so with that and...
Your blood, and most intra-cellular and extra-cellular fluids are 0.9% salt so, if salt were corrosive to bodily matter you'd fall apart in pretty short order.
I'm not so sure on that, neat salt brushed directly onto the teeth and into the gums? I'm no expert but that sounds highly abrasive to me wearing down the enamel and creeping beneath the gumline?
Corrosive? Abrasive? Which are you going for? BTW, salt as a dentifrice is as old as the hills. Soot and salt was a traditional, if odd sounding, toothpaste.
Don't they scream and fizz a lot.
Offline neo
  • The specialist.
« Reply #8351 on: March 08, 2018, 09:11:01 pm »
Was it on a negative voltage rail or something? In such a case, of course, ground is positive.
Two important bits to note,
It is on a negative rail but it is completely unmarked except for in the manual.
When i do something stupid i am extremely hard on myself..... even if it doesn't ultimately matter.
The cap blew itself to smithereens, had to use an ounce of IPA to get the crud back off besides wasting a 2 dollar capacitor and that 2 dollar capacitor with shipping is a 7 dollar capacitor. But nothing more expensive than that blew up.... that i know of yet.
« Reply #8352 on: March 08, 2018, 09:29:09 pm »
Ah, OK. Glad it was just the capacitor. As for shipping, yeah, it's kind of a bummer for small quantities. It's also a pain trying to cluster parts needs in order to make a worthwhile order.
« Reply #8353 on: March 08, 2018, 09:35:58 pm »
I did surmise that you managed to blow the cap, hence your comment about $7, but don't be too hard on yourself, I think we have all done that or similar things at some point in our time, especially as the circuit board was not marked. Chalk it up one of life's experience and a lesson to double check next time.  :-+
The following users thanked this post: neo
Offline neo
  • The specialist.
« Reply #8354 on: March 08, 2018, 10:11:38 pm »
My first time popping a cap believe it or not...
« Reply #8355 on: March 08, 2018, 10:24:58 pm »
I believe it, don't they make you jump as well?
Offline tautech
« Reply #8356 on: March 08, 2018, 10:33:00 pm »
To use Specmaster's sig:
That bl**dy Murphy is always watching waiting for a chance to strike !  :rant:
Offline neo
  • The specialist.
« Reply #8357 on: March 09, 2018, 12:16:28 am »
It takes alot to make me jump, this didn't. Then again it was buried in the instrument and i was too busy trying to flip it off.  :-DD
« Reply #8358 on: March 09, 2018, 01:22:27 am »
I thought a while before I posted this. So far, I have never managed to make a cap pop accidentally. I've nuked a few resistors, and quite a few semiconductors, but never a cap.
I will now tip-toe around for the next few weeks, waiting for Murphy to catch up with me.
Edited to add: On thinking about it, I have had bloody Riva X-class caps go on me, but that doesn't count as it's not through application of my own stupidity.
« Last Edit: March 09, 2018, 01:24:51 am by Cerebus »
Offline Brumby
« Reply #8359 on: March 09, 2018, 03:54:24 am »
I could say the exact same ... but ... this is why I won't:
 ;D
« Reply #8360 on: March 09, 2018, 05:58:41 am »
Likewise. ;D I get enough of a reminder from old tantalum caps shooting into the air when powered correctly.
« Reply #8361 on: March 09, 2018, 07:13:10 am »
I’ve had lots of them go on me:
1. A few mistakes when I was a kid and had no idea what I was doing. This was interesting because most of the ones I played with back then were axial and chassis cans extracted from old radios which have comedic levels of venting ie none. Experiment number 412.  Connect capacitor across AC winding. Result: hole in nan’s curtains.
2. A few not paying attention and not owning a current limiting supply. . One bounced off my head.
3. I suppose this counts but assuming that the line on an SMD tant was negative
And the most important:
4. Hundreds of sacrifices to the Flying Spaghetti Monster just because sacrificing them is fun. I will occasionally buy a bag just to blow up! Better entertainment than a Netflix sub.
Rifa X class are the suicide bombers in the rebellion against my sacrifices. They’ve got me twice now.
« Last Edit: March 09, 2018, 07:15:11 am by bd139 »
« Reply #8362 on: March 09, 2018, 07:52:37 am »
How many volts does it take to blow a 500v electro  ???
Having beer and lots of nibbles in the late afternoon sun  :popcorn:
« Reply #8363 on: March 09, 2018, 07:53:46 am »
Not many volts if you use it wrongly :)
« Reply #8364 on: March 09, 2018, 07:59:06 am »
I have a leftover lot of rather large unvented ones and I am about to salvage a Microwave >:D
« Reply #8365 on: March 09, 2018, 08:26:34 am »
It's your moral obligation to add a large vent to each capacitor via the application of volts :D
Offline BravoV
  • +++ ATH1
« Reply #8366 on: March 09, 2018, 08:34:24 am »
Touch down, its here ...  :P
Only the unit, printed manual and power cord only.  ::)  No probe.  :'(
« Last Edit: March 09, 2018, 08:41:12 am by BravoV »
« Reply #8367 on: March 09, 2018, 09:10:49 am »
Ooh that looks interesting. Let us know how it goes. I am looking out for an SA at the moment so might be another thing to add to the "look out for" list.
Edit: boo hiss. Looks like a couple of resistors have burned as well. Might have to rebuild the vertical amp and test it properly outside the scope  ::)  Smells "interesting".
Replying to myself here on the Tek 465 ... it is operational again after a 2 hour replacement job. Looks like the transistor just gave up. There was no other damage other than to a resistor. I didn't have a suitably rated or valued one so I used two in parallel and that worked fine. There was a moment of annoyance when it showed large trace distortion so I pulled the transistor and measured hfe (DT830 FTW) and it was way off for that transistor. So I chucked another one in and it was fine. The one with the knackered hfe I'd already had on a breadboard so it might have been slightly toasted or zenered.
Offline neo
  • The specialist.
« Reply #8368 on: March 09, 2018, 10:24:53 am »
Nice fix, it is nice to see one so simple.  :-+
I've reached a point of fixing everything to such an extent that all i have left are annoying bastards and cosmetics. Cue the part of me ordering a 7A18 just for it's knobs.
« Reply #8369 on: March 09, 2018, 10:42:07 am »
Ah yeah it's annoying when it gets there. I'm actually having a clear out of dead stuff I'm never getting around to fixing. The near house move actually outlined how bad it was.
Many years ago I lost a battle against a Tek 453 and I'm considering buying another one so I can win that battle again. That's when it gets trouble :)
Offline neo
  • The specialist.
« Reply #8370 on: March 09, 2018, 10:55:39 am »
Given that this is TEA i'm going to take a leap and say buying is definitely encouraged.  :-DD
« Reply #8371 on: March 09, 2018, 11:34:44 am »
Congrats on your victory with the 465 although TBH, it never stood a chance against you. So you want to relive your battle with a 453 then eh. well has it happens there is one on sale that might just give you a challenge, and the biggest one would be the asking price I reckon https://www.ebay.co.uk/itm/TEKTRONIX-TYPE-453-OSCILLOSCOPE/222866547423?hash=item33e3e1a2df:g:QlEAAOSw2C1am~Mj  :-DD
« Reply #8372 on: March 09, 2018, 11:55:08 am »
Ooh now that's suitably manky looking. Not sure why my script didn't pick that one up!
Asking price is way too high for the condition. I'd expect £35 for that including delivery. It's missing CRT graticule cover and the panel cover so will probably skip that.
If you've ever peered into one of them they are bang in the middle of the solid state twilight zone. No tubes (apart from some very early models and then only the amp impedance buffers and they are nuvistors) and no ICs either.
« Last Edit: March 09, 2018, 11:56:51 am by bd139 »
« Reply #8373 on: March 09, 2018, 12:04:04 pm »
Haha, that was my reaction when I saw it, the best use for that is a boat anchor, it made my 1740A look like it was new by comparison.
« Reply #8374 on: March 09, 2018, 12:09:20 pm »
Yep they are boat anchors. There is the 454 of course which was a bit of a break through. 150Mhz bandwidth in a portable scope in 1968 (!). I might hang out for one of the actually.
They are built like apollo space craft. Cast, machined, neatly wired, incredibly well documented, the lot. Gold plated everything. Designed to withstand drops!
Vertical amplifier
More pictures: http://www.helo.de/helo/tek/portable/454/454_e.htm
http://elektronikbasteln.pl7.de/reparatur-eines-tektronix-454-oszilloskop-150-mhz.html
« Last Edit: March 09, 2018, 12:11:51 pm by bd139 »
