For CAD$112/US$90, this one's a keeper, I think. The different design means I can push the whole objective up in the elevator cradle like this, so none of it protrudes below the metal bracket, which means no worries aboot accidentally touching it with the hot air handset. ![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
I'll probably print up a ring spacer to make it easy, and to support some auxiliary lighting. As you can see here; with the elevator angled back just a wee bit, the reflection glare goes away and I can get in there easily with elevation at ~80mm. Magnification at 80mm is approx the exact same as the other one was at 20-30mm.
Resolution to the PC doesn't seem as good as the other one at 20-30mm; not as crisp. But it is still more than good enough I think. Overall, this 'scope has much better usability.
Difference is this one is made to work on stuff, while the little one is just made to look at it. ![Tongue :P](https://www.eevblog.com/forum/Smileys/default/tongue.gif)
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1134772;image)
Getting back after this project. I've printed up the spacer ring; that works nicely. However, what appeared as a minor problem has gotten substantially worse. When I first got this thing, the hinge had a little bit of back forth slop that was at most an annoyance. With handling from working on the spacer ring, that got progressively worse to the point where using it made the thing flop around so much it wasn't possible to focus properly.
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1134776;image)
Here we can see the cause; that visible gap under this end of the hingepin. This hingepin has a 2-piece shank with a hollow conical collet & tapered pin to make a friction joint. I took a pic of this but the photography gods decided that one pic was going to go blooie; I'm not tearing this hinge apart to take another.
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1134780;image)
Anyhoo... the ends of the hingepin are only held fast by a single grub screw in the same thread as the m4 base screws. Without them, the hingepin is loose in the U-bracket. For some reason, they only made it with a grub screw on the one side.
![WTF? :wtf:](https://www.eevblog.com/forum/Smileys/default/wtf2.gif)
The other side, with that visible gap, was left to flop around unsupported. This eventually allowed the one grub screw to work looser and looser.
At first I thought someone just forgot to install 2nd grub screw but no; the hole was not threaded all the way through. A few minutes with drill & m4 tap had that sorted; however I didn't have any m4 grub screws so I made that butt-ugly little fellow from a hardened m4 bolt. Hopefully, a drop of LokTite blue on each will prove adequate to keep things from loosening up again.
Right now it has a delightfully tight hinge with absolutely zero play in any direction; I'll update here on how it holds up after I have some time to work with it.
For now, time to get some more practice in on scrap boards.
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=904256;image)
