Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 18796202 times)
salvagedcircuitry and 129 Guests are viewing this topic.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #6775 on: January 31, 2018, 08:28:20 am »
If you want to get yourself in trouble, go here and start downloading catalogs.
http://www.hparchive.com/hp_catalogs.htm
Those from the sixties and early seventies will provide the most search fodder for nixie addicts.
Your counter must be later than ’72 and earlier than '77 (the two I looked at), because the '72 didn't show the opt 011 oscillator, and by '77 there was no more option 1 - that catalog states that all of them come with 8 digits.
-Pat
« Reply #6776 on: January 31, 2018, 08:33:05 am »
Damn, dude - I just looked at the 'bay, and if that's the one I think it is, you stole it!!  REALLY nice score!!
Thanks, Pat. I was really reluctant to go for it since there was no activity on it. I was the only one with a watch on. Perhaps it was because it was listed several times before at a much higher (though not terrible) starting price.
Just what I needed. :palm: :-DD I shall peruse them with care. ^-^
Very interesting. The manuals I've seen must've been for the earlier models (no 011).
Offline Cubdriver
  • Nixie addict
« Reply #6777 on: January 31, 2018, 08:56:25 am »
That one's not in my search anymore as it's usually maxed out and I need to prune something every time something else catches my eye, otherwise you might have had some competition.   :-DD
Oh, and if you want to really get in trouble by way of the catalogs, do what I foolishly did and start tracking down and buying the hard copies! They don't seem terribly expensive at typically about $20 a copy, but that cost is just the beginning!!   >:D >:D >:D
Based on the auction photos, it looks a little dirty, but I bet it will clean up nicely with a little elbow grease.  I've found that taking the sheet metal panels off and soaking them in hot water with some ammonia and dish detergent cleans them up quite effectively.  I scrub them with a fingernail brush, and hit them with a sponge as well.
I see it looks to have its feet in addition to its badge, too - excellentl!
-Pat
Offline VK5RC
« Reply #6778 on: January 31, 2018, 11:26:10 am »
BEWARE bitseeker of the evil Cubdriver tempting the youth of today with the 'pornographic' publications of the past (known as the HP Journal) or even more seriously the Catalogues!
I now realise a NEED for 5327, I have the 5326 and the 5328. I must resist..............
Nice find bitseeker. :-+
Seriously I have just found my first ever crystal failure (in a Yaesu transceiver FT 101, the LSB oscillator) when it has turned into a DC resistor of 260 \$\Omega\$. It is in a weird HC6U carrier, 3181.5kHz and has a very low equiv series resistance ~40 \$\Omega\$ when working properly, the only way is a whole board - they are available. I might try a newer crystal with a bit of circuit bodging.
« Reply #6779 on: January 31, 2018, 12:11:00 pm »
I'm forever buggering up crystals. I didn't know you could make them hot until recently  :-DD
I found a few as well, particularly in Heathkit stuff, that you have to give a flick to get to oscillate or they get fussy about load capacitance. Found a local guy who makes them to order in the end for a small fortune which solved that problem.
Offline Berni
  • Country: si
« Reply #6780 on: January 31, 2018, 12:27:52 pm »
I found a dead crystal in my keithley electometer. That one was completely open circuit. Used a really odd ball frequency too in a weird big can so finding a replacement was quite a search.
« Reply #6781 on: January 31, 2018, 12:35:27 pm »
How did you manage to do that, wack it across an output of an amplifier to use as a mini speaker  :-DD Seriously though how you check a crystal is OK?
« Reply #6782 on: January 31, 2018, 12:43:04 pm »
Well if you add a lot of feedback to a crystal it can get hot. Usually this knackers it permanently. This was in a poor attempt to make a VXO with a 12AT7 valve. I managed to blow up the valve, three crystals and zap myself twice in the process. Then I crawled back to transistors with my tail between my legs.
How do you test a crystal is ok? Two options: built a crystal activity test rig or build a simple oscillator and connect it to a counter. I did the latter and it looks like the following. There's a 2 pin jumper that allows you to chuck 33pF in series so you can measure motional parameters from frequency shift to build crystal filters.
Edit: btw the rationale behind the above is that crystal filters are bloody expensive so (£100+ for a decent CW one) so I'd rather buy a shit ton of crystals from aliexpress (200 off so far) and knock my own ones out through selection.
Reference articles:
https://www.arrl.org/files/file/QEX_Next_Issue/Nov-Dec_2009/QEX_Nov-Dec_09_Feature.pdf
« Last Edit: January 31, 2018, 12:47:13 pm by bd139 »
Offline ChrisLX200
« Reply #6783 on: January 31, 2018, 12:57:43 pm »
Yep, I've made a crystal tester circuit too - and then there's also the [inevitable] Chinese gadget that does the job...
« Reply #6784 on: January 31, 2018, 04:52:42 pm »
So... did you test the crystal in your crystal tester before you used it to test other crystals?  :-DD
*Crawls back into my hole*
« Reply #6785 on: January 31, 2018, 04:56:08 pm »
And that's how you become a time nut. Clearly to test a crystal you need a GPS disciplined oscillator attached to a counter to make sure the counter is counting correctly :)
Or you lucky Americans who can just zero beat WWV
« Reply #6786 on: January 31, 2018, 05:01:23 pm »
...sounds kinky. ;) I'll shoot video for social media...  :P
"Oh, I beat my knee with a monkey wrench, cuz it feels so good when I stop..."
« Reply #6787 on: January 31, 2018, 05:29:32 pm »
Interesting, how accurate is it?
« Reply #6788 on: January 31, 2018, 05:33:49 pm »
No, you use the GPSDO as the master clock input to your VNA, and then test the crystal with that. Obviously after calibrating the VNA with a set of metrology grade connectors (short, open) and air line, all of which you check with a laser interferometer, that you check with a maser interferometer, that you phase lock to your GPSDO.  :)
« Reply #6789 on: January 31, 2018, 05:53:22 pm »
Good news, my rather scruffy pair of Fluke 27's arrived today, 2 days ahead of when they were scheduled, thanks RM. Anyway I tested them out before cleaning and all yellow one was pretty good but the latest one, CAT3 was all over the shop. Anyway, stripped them down, cleaned switch contacts with Servisol Super 10 and the input sockets connections on the PCB with a fibre class pencil and the screws.
Cleaned the cases with bathroom cleaner and a toothbrush, dried and re-assembled them and tested against known values and they were .001v out and the resistance ranges was equally out buy .001 ohms so pretty good.
Here's some before and after shots and before they were looking like proper dog turds and now they look like the muts nuts as their always licking them. So I'm still looking for a 27 case so that I can stick the 25's guts in it and then I have 3 pretty good meters that are pretty much bang on the money as calibration as there is only 1 count out between all three of them so I'm a happy bunny.
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #6790 on: January 31, 2018, 05:57:03 pm »
Good job on the clean-up.  :-+
« Reply #6791 on: January 31, 2018, 06:15:12 pm »
Looking good! Makes me want a 25 :)
« Reply #6792 on: January 31, 2018, 06:27:17 pm »
Why a 25 and not a 27? Extra functions then.
« Reply #6793 on: January 31, 2018, 07:06:50 pm »
Offline ChrisLX200
« Reply #6794 on: January 31, 2018, 07:14:57 pm »
It's as good as I could measure down to its last digit (based on my Tek scope readout and Racal 1998). I've since bought a Racal 2022 counter so I guess I should re-test the thing to confirm that. Doesn't do high frequency though, quoted 20MHz tops but it does go a bit higher than that.
Offline ChrisLX200
« Reply #6795 on: January 31, 2018, 07:16:54 pm »
« Reply #6796 on: January 31, 2018, 07:20:54 pm »
That's just so crazy, how does that compare to yours now that you've cleaned it up a bit?
Its in beautiful condition though, looks like not been used more then a few hours, wonder if the bidders were buying on behalf of a museum, that might explain the high price.
« Reply #6797 on: January 31, 2018, 07:35:09 pm »
It’s a storage scope which is the only reason I can think of. Problem is there is a superior 7623 floating around on eBay for weeks which didn’t even get a look in.
« Reply #6798 on: January 31, 2018, 09:54:05 pm »
Oh! Lucky me. :phew:
LOL! Nope, I'm OK with the soft copies even though paper is nicer for browsing.
For how long do you soak them? The sticky surface on my 3468A multimeter took several rounds of scrubbing to get clean. Pretty stubborn stuff.
Yep, it sure did look that way. Maybe the tilting bails, too. That'd be great as I don't have extra feet for HP stuff of this vintage.
« Reply #6799 on: January 31, 2018, 10:01:10 pm »
Haha! He's quite the enabler. Kind of appropriate the "driver" in his name. :-DD
Thanks. So what's your newly realized need relative to the 5326 and 5328? 500 MHz? The 5328 has nice plug-in options.
