Guys, can ask your opinions on what is the best kind of wire stripper? I have a couple very similar to the one shown as some of you will know I have to replace a 8PDT push button switch on a Solartron 7150 plus DMM and I'm struggling with these strippers to make a decent strip on the wires of this meter. It uses a cable, the likes of which I have never come across before. They are single solid cores and very stiff, they oppose almost any attempt to bend them and the insulation sticks to the cores like shit to a blanket. The cores themselves have veins like a leaf embossed in them and the insulation does not want to let go of the core.
I have extremely little room to work as the cables don't have any real slack available and as you can see, they are so stiff, they have to be physically anchored at each end and the main outer sheath is like an insulted armoured cable between the two boards, and there are 2 such cables, the switch itself has 3 of these cables connected to it.
I have been considering rewiring these with a more workable and friendly cable, but if I did, what type of cable should it be or is the cable on these meters dependant on the that type of cable for some reason that I'm not aware of?
So the question is what is the best kind of cable stripper to use and also what are thoughts on the type of cable used in these meters, could another be used without any detriment to meter itself and if so, what cable would you guys use?
