Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 18795897 times)
salvagedcircuitry and 355 Guests are viewing this topic.
Offline 0culus
« Reply #61550 on: June 22, 2020, 03:02:56 am »
So I tried to power up the 585A with the time delay relay tube removed, and it popped the fuse after almost starting. Gotta delve into the 100V rail now, as that is always on whether or not the time delay has tripped or not.
I haven't looked at the 585A schematic but if the 100V rail is always on it sounds like it's the reference for all the other supply voltages, correct? Try to isolate it from all the other supplies to see if it stays up by itself. If yes then you have to determine which supply is drawing excess current when it's sequenced up.
-150 is the reference supply according to the manual. I maybe found a dead shorted cap in the heater supply though...C786, a filter cap. + to ground is less than 1 ohm which I'm preeetty sure should not be the case for a cap! [edit] this is wrong...I keep getting screwed up by how the heaters are wired. I need to lift one leg to confirm.
« Last Edit: June 22, 2020, 03:05:03 am by 0culus »
Offline Brumby
« Reply #61551 on: June 22, 2020, 03:08:29 am »
Philips ... Televisions ... I'm suddenly thinking K9.
Am I showing my age...?   ;D
Yes, you are skipping K6, K7 and K8.
NOW who's showing their age?   ;)
K-9...?
 :o
If anyone was going to be first with that one, I'd have put money on it being you....
But I doubt anyone here would have taken that bet.
« Last Edit: June 22, 2020, 03:10:08 am by Brumby »
Offline Brumby
« Reply #61552 on: June 22, 2020, 03:11:25 am »
You guys have this all screwed up. The K9 is the sleeping Furry thing the K8 is the grinder in front and the K10 is the grinder at the rear  ;D The Coopers Beer just happened to be there  :-DD
You seem to have a Grinder fetish.
« Reply #61553 on: June 22, 2020, 03:13:41 am »
Those two are the 'normal' market attendees the K9 is of course departed a few years ago. There is also another K8 in the Shack and two other full sized commercial grinders. I don't have a problem really  :-DD
« Reply #61554 on: June 22, 2020, 06:37:35 am »
Says the one which is a core member of the TEA thread.   :-DD
« Reply #61555 on: June 22, 2020, 06:43:36 am »
Typically K9 Chassis from Philips. Repaired many of them in my early days.
Source:
https://obsoletetellyemuseum.blogspot.com/2012/01/philips-26c46558-chassis-k9-internal.html
Offline PA0PBZ
« Reply #61556 on: June 22, 2020, 07:03:32 am »
That brings back memories of one of the 2 green HV caps dying and effectively doubling the HV, the 1u cap in the sound chain going bad, the sticky on/off switch that got a recall, the tuners not really up to lightning and the blown BU's (this was my first encounter with a SMPS).
« Reply #61557 on: June 22, 2020, 07:16:05 am »
I’ve probably said this before, but I always admired Philips’ ability to produce every part for their products in house.
« Reply #61558 on: June 22, 2020, 08:05:41 am »
That way you're in control of quality and quantity. It was exactly the same at Crabtree Electrical when I worked there, even made their own springs and screws etc in house.
« Last Edit: June 22, 2020, 09:49:53 am by Specmaster »
Offline tonyalbus
    • My Channel
« Reply #61559 on: June 22, 2020, 09:23:40 am »
Oops i did it again   :palm:
and a HP 3478A on its way ....
Not sure about this terapy, but atleast we talk about it... :-DD
« Last Edit: June 22, 2020, 09:27:03 am by tonyalbus »
The following users thanked this post: BU508A, mnementh, Kosmic, TorinoFermic
Offline PA0PBZ
« Reply #61560 on: June 22, 2020, 09:29:22 am »
Are you sure you have enough frequencies to count?  ;)
Offline tonyalbus
    • My Channel
« Reply #61561 on: June 22, 2020, 09:31:53 am »
Yes i like counters, the HP is a nice backup for the TTi and the Marconi is just to company the 2955
« Reply #61562 on: June 22, 2020, 09:33:04 am »
I've been encouraged and prodded by this group several times to get one of those but I don't like the LCD display. Gotta be ruby red LED's or I'm not playing.  :-DD
So, of my extensive TE collection the only HP is one lonely power supply.  :-//
« Reply #61563 on: June 22, 2020, 09:42:28 am »
Med, what do you think about this one?
Source:
https://hackaday.com/2019/10/30/multimeter-display-perked-up-with-nixies-leds-and-neon-tubes/
The following users thanked this post: edavid, bitseeker, mnementh, wolfy007
« Reply #61564 on: June 22, 2020, 09:45:09 am »
Nixies I can get along with.  :-+
Offline tonyalbus
    • My Channel
« Reply #61565 on: June 22, 2020, 09:45:37 am »
Source:
Super cool! :-+
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #61566 on: June 22, 2020, 10:10:45 am »
Speaking of which... I have a PM6654 here (1.5Ghz option), which unfortunately is bad. Would you be interested in a repair attempt? Shipping back and forth is on me. If you can repair it, you've had fun and I have a sellable meter. If not, eh, well...
« Reply #61567 on: June 22, 2020, 10:15:46 am »
Source:
What black magic fuckery is this? I'm both sickened and liking it at the same time  :-DD
Offline nixiefreqq
« Reply #61568 on: June 22, 2020, 10:57:15 am »
Source:
that is just WRONG!  WRONG! WRONG! WRONG!
(hmmmmmmm.  i have plenty of spare tubes and drivers.  need to check ebay for a borked 3478.  wtf is wrong with me?)
edit.  have a boatload of hp dot led displays (w/the bcd decoders on the chip)......maybe that would not be quite the abomination?
« Last Edit: June 22, 2020, 11:05:29 am by nixiefreqq »
free range primate
Offline Wolfgang
    • Electronic Projects for Fun
« Reply #61569 on: June 22, 2020, 11:09:09 am »
Source:
Super cool! :-+
My suggestion - replace all this by a super cool modern OLED display showing nixie tubes. :)
The following users thanked this post: PA0PBZ, wolfy007, tonyalbus
Offline Brumby
« Reply #61570 on: June 22, 2020, 11:21:00 am »
Source:
Ah ... a cool head at last.
:palm:
Offline Brumby
« Reply #61571 on: June 22, 2020, 11:22:52 am »
I suppose I should expect this with Nixie fans......
*sigh*
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #61572 on: June 22, 2020, 11:43:17 am »
Looks like something the hp engineers might have tried back in the day to keep Carly Fiorina from dropping the hp name from test equipment.  :palm:
Offline VK5RC
« Reply #61573 on: June 22, 2020, 12:27:25 pm »
Re the 'new' 3478 ,I appreciate the removal of any LCD - the only electronic display that I dislike with a vengeance (except on a 41C calculator), I propose replacing the display with some good LEDs, they are not too far from the vintage of the button design etc. Nixies need an entirely different front panel.
PS one of my 5245L is going to a new home on the weekend! A period of mourning, hopefully off to be looked after well.
Offline psykok
« Reply #61574 on: June 22, 2020, 01:25:11 pm »
It would appear that someone is not telling the truth.  :-// ;D
Yes, but I'm not worried. All three need to be calibrated but before doing that,
the Fluke 732A needs a new battery pack. The one inside is dead as a dodo.
I'm thinking about replacing it with a Li-Ion pack (the original ones are Pb-acid).
The advantages would be:
- less weight
- increased capacity. The Pb-acid batteries are good for 2 days uptime, with the Li-Ion a week could be easily achieved
Disadvantages are:
- needs a different charger, therefore a modification of the PSU of the 732A. Maybe not a so good idea.
- sending in to a cal-lab would be problematic because of the restrictions of the delivery service companies.
I hoped, I could discuss this topic at the Metrology Meeting in Stuttgart, but this meeting got canceled for well-known reasons.
Was not aware  for the metrology meeting, that something I definitively  need to attend next time it will found place.
BTW I replaced the battery from my 731A with new LiOn one and he now back in business :D
