The Type 561B now has it's turn on the torture rack. It will go through several burn-in cycles to make sure everything is up to snuff.
The mainframe itself and the Type 3A3 Vertical plug-in are complete and 100% functional. The Type 2B67 Time Base plug-in has a good sweep but it refuses to trigger lock. I have a Type 3B3 Time Base coming this week that is complete and hopefully functional.
Since the Type 2B67 won't trigger on repetitive signals the Type 3A3 is currently connected to the audio output of the police/fire scanner and will just display random audio when there's a transmission.
I also have a Type 3A6 Vertical plug-in but it needs work. It displays traces on both channels but neither channel will pass a signal. That and the Type 2B67 will require troubleshooting via an extender cable to gain access to the component side while it's powered up. I'll have to make up a cable myself. That's a follow on project for a later time.
![](https://imagizer.imageshack.com/v2/xq90/922/sKTcAN.jpg)
