I like this one; it's "Classic Linus" style.
Note that Linus is using the same case I chose for my Ryzen 7 Build; mostly for the PSU Channel/cavity design with glass side and dual 120/140mm top rad and dual/triple 120/240mm front rad for $37 on the ShellShocker. This configuration, IMO, is a MINIMUM requirement for any modern build. The fact mine came with RGB lighting was a "Meh..." point for me; it meant I could color-coordinate with my LED thermometer, but once the LED color was set to blue, I disabled the color management and forgot about it.
Good building!
Thanks for that video link. That gives me a good baseline to compare against. Definitely my budget is aligned with what is in Linus' video. I get the impression from the video that he is Canadian from a couple of his comments, but I am not sure that $800 price is Canadian. With a few changes (double the memory, different case, different SSD), I was almost $1300 looking at CanadaComputers.com, NewEgg.ca and Amazon.ca. Have I missed a source, did prices jump that much in 2 months, or is his baseline $USD?
I have picked up a few details on modern hardware. However, I expect I have not got all the knowledge needed, so I will likely check back later. I will also keep an eye out for deals as I do have a bit of time.
Thanks mnem!
