salvagedcircuitry and 49 Guests are viewing this topic.
Brand name kit gives you no guarantees past someone to lick your butt if it goes wrong and possibly some form of traceable cal and safety certification.This is incidentally the same reason I end up building kit occasionally: I get fed up with the design and shipping flaws in other stuff. I can design out as many flaws as I need to and make my own compromises that I am aware of. Usually more compromises but in the right places
Got home from holidays on Wednesday after 10 brilliant days on the Central coast of NSW, paid my local post office a visit and collected 4 parcels including my Quicko T12 Soldering Station. In true EEVBlog style I took it apart without turning it on first! Mines the "compact one" like SpecMasters:It needed some TLC as many of the soldering joints were frankly crap and the PCB needed a clean with Isopropyl! I re-did all the TH joints with some 60/40 Rosin core solder:and the control board TH joints weren't greatimproved:I cant believe how small this thing is and how fast it heats up! Super Impressive and really nice to solder with, the handle is so light and your hand is so close to the tip the control you have is great!I have found the tip temp display seems to jump around a lot but for the money im not complaining. I just need a proper handle holder for it and something to hold the tips not being used (the tips are all really nice quality too, this was very pleasant surprise).High res pics for those wanting a closer look: https://imgur.com/gallery/f5We0
Delivery finally!One Thurbly Thandar PL154 15V 4A supply arrived. Not only is it in good condition, but it has the shorting bars, was well packaged, works 100% correctly and is in good physical condition. £30 well spent (+£14 delivery) Don't turn it on, take it apart. Seems to be manufactured about 2000:Now turn it on...I chucked a few resistors across it and measured current and voltage and it is pretty spot on Also batteries arrived for my TF930 counter. Will install them this evening.Just in time for the weekend
Quote from: bd139 on January 05, 2018, 12:53:39 pmDelivery finally!One Thurbly Thandar PL154 15V 4A supply arrived. Not only is it in good condition, but it has the shorting bars, was well packaged, works 100% correctly and is in good physical condition. £30 well spent (+£14 delivery) Don't turn it on, take it apart. Seems to be manufactured about 2000:Now turn it on...I chucked a few resistors across it and measured current and voltage and it is pretty spot on Also batteries arrived for my TF930 counter. Will install them this evening.Just in time for the weekend I'll say this...It is very colorful inside. Looks nice.
Made here in the UK too!Hopefully not like this:
What is it with you Limeys? You drive on the wrong side of the road, you put your power switches in upside-down.... <ducking> -Pat
Our power switches turn off when you lean on them and our dominant hand is conveniently situated on the side you can stick it out of the window to make signs at other drivers
Now yours looks like mine with those batteries installed [emoji106]
Quote from: bd139 on January 05, 2018, 05:44:29 pmOur power switches turn off when you lean on them and our dominant hand is conveniently situated on the side you can stick it out of the window to make signs at other drivers Mine too - I'm a southpaw! -Pat
Quote from: Specmaster on January 05, 2018, 05:56:59 pmNow yours looks like mine with those batteries installed [emoji106]Yeah mine looked like that before as well Quote from: Cubdriver on January 05, 2018, 06:02:46 pmQuote from: bd139 on January 05, 2018, 05:44:29 pmOur power switches turn off when you lean on them and our dominant hand is conveniently situated on the side you can stick it out of the window to make signs at other drivers Mine too - I'm a southpaw! [emoji14]-PatHahaha you are optimised for your location
Nope exactly the same cells. Just knackered.
Yep. I always buy Gp batteries anyway so I was rather happy to see some in that.
Looking good! Nice bit of tidy work there as well. Interested to see how they compare to other irons. I just got two notifications from aliexpress this morning saying my package has arrived in the U.K. Thought hey it’s the T12 iron! Turns out unfortunately not. Got the 9501 handle and 200 UV LEDs.This is becoming a serious “issue” I think. TEA is bad but I think there’s another thing that is developing. Case in point: For some strange reason I am now the owner of 500 3mm LEDs. I don’t need that many but it was only £0.80 for 300 more than the 200 I didn’t need to start with. I will be stress testing them. Hopefully they blow up spectacularly like the LEDs I used to buy from Tandy in to 1980s and not like the ones you buy from reputable dealers that just go dark. Oh and 60 TO92 voltage regulators because I need some 78L06’s and can afford to wait. Oh and some 2n3904’s because I’m interested to see if the no brand ones are any worse than the On Semi ones I’ve beem buying by the bucket load. Oh and some no brand TL431’s (this is my favourite IC) so I can build some current sinks for the above LEDs.
