Fascinating, mines sitting in my parcel locker back in Melbourne and I'm on holidays 950 kms away in the central coast of NSW - argh I really want to see what mine looks like now!
Whatever yours turns out to be, I'd seriously recommend changing the connections between the IEC mains power socket and the PCB and also carry out proper earthing for casing.
To complicate matters now, I'm debating what parts or system should I go with for my second model, stick with Quicko and their 4 pin system or go for another make with the more normal 5 pin system which means I can prewired handles that will work without any modifications...problems ... problems...
Yeah will do, I've been following your posts so I'll come back and check them again when I get my hands on mine.
I'm not sure I can be bothered getting another just for the 5 pin connector, as long as it works well and is rendered safe I'll be happy.
I was also thinking the same but then again mnementh was saying we'd be trail blazing these Quicko ones on our own as he has never used them and so has no experience, so that got me to thinking, I'd like to do a comparison between a typical system that he'd put together (apart from his style of enclosure as I have zero means of doing the metalwork that he does) and the Quicko. The costs are reasonable and I've just got my Birthday and Christmas money in the budget so I thought why not. Like multimeters, you can never have too many soldering irons. Well you can but they take up so little space and are energy efficient so...
Well, the "Blue" OLED T12 Controller I use
(US$14-17) comes as a kit intended to convert one of the old clone Hakko 936 stations by recycling the transformer & rectifier already inside the unit. They come with with the controller, a smoked acrylic faceplate (that fits on the end of these extruded cases
(US$9-10) OR can be fitted to an external box), the 5-pin mini aircraft connector and the thermistor + ball switch as seen in the photo below.
If you get the Ayima FX-9501 handle
(US$9-10), it is prewired for the "Blue OLED T12 Controller" and will plug right in; the included thermistor, ball switch & female aircraft connector become spare parts. Depending on where you shop, you can get 1-20 pieces of assorted T12 clone tips with the controller or as a side order; After a lot of searching, I settled on the most common 10-piece assortment as the best combination of useful tips vs cost
(US$22-25). This assortment is available from a number of vendors on AliEx.
Some folks will prefer the FM-2028 modular handle
(Clone versions US$10-15); these use a foam-covered grip that stays on the tip to facilitate quick convenient swaps. They are what currently ships with the genuine Hakko FX-951. So far, I haven't found the FM-2028 in a version that's prewired for the OLED T12 Controller; these usually come with an 8-pin DIN connector to plug into the genuine Hakko FX-951 station. This means you'll have to rewire per the schematic diagram below.
I wanted to build another one that could be powered with anything from an old laptop power pack to a 4S LiPo, so I intended to use a 150W Boost converter
(US$3-8 depending on where it's coming from and how fast) inside the box to run it at regulated 24-28v no matter what the input voltage; that was what the extruded aluminum enclosure was for. I have an RFQ in for 2 of them from a listing by a wholesale electronics vendor
(US$17-28), but confidence in said vendor is not high as no response after 3 days.
My 3rd choice is this plain black enclosure from Amazon
(US$17); it would go well with the smoked acrylic front panel that comes in the kit. But as you can see, sortof like stepping down from a Delorean to a Ford Ranger for almost the same money; so I'm loathe to throw in the towel on the extruded enclosure just yet. Once I get caught up on some bills I may try and just place an order to see if they show up, cost be damned; but right now I'm deep in a hole due to Christmas and emergency dental bills.
Banggood.com has a 100-220VAC-24VDC/4A SMPS that will fit inside any of these enclosures
(US$7-12 Depending on where it's coming from). It has grounded screw hole mounting and fused input, so the non-fused power plug on their extruded shell is a non-issue.
The last part of the equation is the stand; I have a couple of these clone FX-951 stands
(US$10-12). One came with my MLiNK S4 and I liked it so much that I bought another to mod to make a sleep cradle for my MetCal. They're all stainless rod and epoxy-coated cast aluminum; the design is very flexible in that you can get one of the brass scrubbers in a can and put it in the round recess or put a sponge there. I put a brass scrubber in the well under the tip and a sponge in the round recess.
The only caveat so far is that I've gotten a few of the T12 tips that were warped or slightly mismolded and needed some trimming of the plastic around the slip rings so they'd make good contact reliably.
One thing I did notice is that Banggood.com is offering a 10% off coupon code ( WELDTOOL ) good on all non-special-offer soldering gear; so you can save a few dollars on the stuff they have, like this nifty T12 Tip/Tool Stand made from machined HDPE
(US$7-12).
Hope this rundown is enough info for you to make your decision,
*Toddles off to ded*
