At 35MHz, i'll let it go then I'm well covered at the bottom end, the probes and adaptors look good but again, they will be more suited to the lower frequencies I guess.
I have used Mauritron before when all else has failed and they didn't seem to be too bad though.
I think I was the only person actively engaged in TEA one way or other yesterday as nobody posted anything apart you (bd139) and I and I'm loving this T12 iron kit, you can literally switch it on in the morning and leave it running all day long and it uses hardly any power as it switch in to sleep mode (set mine for 1 min) and then after another delay (mine is 1 min) switches off together and leaves the display on. Just picking up the iron will switch it back on and in about 8 seconds its up to your set working temp, what a piece of kit. Ready when you need it and energy efficient as well and has a very very small footprint.
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
