As you may recall, Brumby accidentally broke one of the small green buttons on an hp 1740A. I was investigating the same type button (not green) on an hp 3457a. I wanted to compare it to a CAD file I found here on Thingiverse -
https://www.thingiverse.com/thing:3057821
Thank you!
But simply pulling it off with my fingers collapsed it. The plastic on these older parts is becoming very brittle.
Or, like on yours, you could make the printed button the "Sweep After Delay" button because it is sort of by itself. But then you risk busting other buttons mucking with them.
Yeah .... that's a worry - but I like the idea.
Good Luck Brumby, now you have a project (as if you needed more). Look forward to the pics!
My project list is getting longer - and reorganising my work area is one task that's getting more challenging every time I look at it. It is often frustrating to mentally assess new ideas and try to come up with a final layout where everything I need (a non-trivial discussion in itself) is convenient, but not crowding AND which all fits in the space available. My recent 24cm space acquisition marks the end of any further such negotiations for the
long term foreseeable future, especially when I indicated was after only 20cm. (Those extra 4cm required shifting a couple of hundred kilos of other furnishings - which I only got away with** by doing when there were no witnesses in the household.
** The jury's still out on that. I think they sense something is a little "off" but can't put their finger on it. After another couple of weeks, I think that feeling will fade and the current arrangement will become the new norm.Then, once I have settled on a design choice for a particular feature, I have to do the construction. I have that next step already defined - but it involves modifying an existing piece of shelving that is an integral part of my current setup. Getting it out to work on will involve removal of a few dozen items (not a huge issue) and wrangling more than a dozen cables (a major pain).
Then there's the list of other workspace mods...
