Would it be wrong to buy a 3rd Agilent/HP device in a week
Wrong? Sounds like a good start to me.
-Pat
I was just thinking that if you can swing it, it would be wrong NOT TO...!
Turns out you you can get the OLED equipped T12-952 with the 9501 handle for $70 AUD including 5 tips ... I'm seriously tempted to sell off some Bitcoin and grab one! I've always wanted a station with the JL02 style tip for drag-soldering SMD chips.
Ok I caved and bought the single tip set for $56 plus the 10 tip pack for $30, for $86 delivered it was too cheap to pass up.
Just had confirmation that my solder station and the 9501 handle has been dispatched, cant wait till it gets here
That sounds like an AWESOME DEAL for those who don't want to be bothered to build it themselves. I got into all this soldering iron tech because I
WANTED NEEDED TO KNOW how it worked; the Nuts & Volts of it all is what makes me HAPPY. Guess it's part of being born with "The Knack"; I don't mind figuring it out myself.
For those who already have a plethora of appropriate power supplies and who don't mind building it themselves, you can get it all for ~$40 like I did.
Just be aware guys that this is the first I've seen of the Quicko store on AliEx; like everything China-Direct, these vendors come & go. Everything I linked to was because I could personally vouch that the quality was at least half-decent. There were plenty of purchases (like the hack 907/937 handles and a couple over-rated regulator modules) I purchased during the my journey that turned out to be utterly craptacular. The blue Hakk0 (Yes, seriously) labeled T12 OLED board is pretty well-known to be of decent quality; it was originally developed as an open source upgrade/repair project for folks who had one of the cheapo Hakko 937 clones where the controller board burned up but still had a good 24-28V transformer/rectifier bridge sub-assembly inside the case. Yes, this is a pretty common failure on many of them; even the better ones like the Aoyue. However there are oodles of similar boards out there like the Quicko that are based on the same open source design but you don't know where a particular manufacturer may or may not have cut corners. It does appear to use the same open-source Menu-driven PID loop firmware as the blue Hakk0 controller, though.
Bottom line is that y'all are trail-blazing with this brand; I don't have any direct hands-on with it. If it proves decent and reliable, I want to know so I can recommend it.
That said... do yourselves a flavor and open it up and carefully inspect all the solder joints inside your unit and handle BEFORE you power up. This is a practice I learned to follow the hard way long ago with all my China-direct purchases; in most cases, it's a LOT less hassle to touch up a poorly-wetted solder joint or remove an accidental bridge than it is to get warranty satisfaction from these guys half a world away.
Cheers,
Hmm. Something new under the sun.
