Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 18796187 times)
salvagedcircuitry and 127 Guests are viewing this topic.
Offline Brumby
« Reply #42025 on: November 01, 2019, 08:17:03 am »
 :palm:
You guys are dangerous.  I've just spent the last hour looking at NanoVNAs.
No ... I don't need one.
* turns to the 3D printer still patiently waiting *
Never enough hours....
« Reply #42026 on: November 01, 2019, 08:18:46 am »
I have seen Bananas straighter than this POS molding. Time for a beer to decide what to do about it and even if it will help keep the zebras in the right spot.
$60+frt for the frame and $230 for the LCD if it needs it  :o
Thin strip of high density foam ?
« Reply #42027 on: November 01, 2019, 08:31:48 am »
Full strip clean of zebras, contacts etc and re assembly yielded the same LCD fault. As it is only a single path and the lower bars on the upper digits it is still translatable.
The Zebras are held in position by the four white clips to the pcb and any cantilevered force from the three  :palm: screws holding the board in the case. Evrything at the top of the PCB is flapping in the breeze between the outer case.
It is still possible that a PCB or the outer frame warp is stopping the zebras from contacting bit I am leaning toward the LCD having a dud track.
I think it suffers from being the bastard love child of Fluke and Martel who forgot to consider some basic mechanical design considerations.
« Reply #42028 on: November 01, 2019, 08:34:29 am »
Hmmm, a sleep on it usually helps.  :-//
« Reply #42029 on: November 01, 2019, 09:00:39 am »
Good advice.
Certainly a pain. All Flukes seem to suffer LCD problems  :--
I noticed that when Heathkit ripped off the Fluke 8021 they used a standard LCD module with standard pin layout. The side effect of this is you can still get exactly the same module. While I like some of the custom LCDs we’re an in age now where everything should have standard matrix LCD modules and all the fun stuff done in software.
Offline URI
« Reply #42030 on: November 01, 2019, 09:09:07 am »
I can confirm that.
Today I feel it's better to skip the 5373A and to go for a 53310A with option 031.   >:D
Thanks all for helping me with their thoughts on it!   :-+
« Reply #42031 on: November 01, 2019, 09:16:15 am »
Sleep might help the thinking but it won't help the nearly 70mm of floating PCB/LCD above the screws. There is room where the Fluke and Martel logos sit to have added two more screws so it is either an ego Branding or dumb dumb engineering fail. Adding a wedge to the slots in the case insert might help keep the board in place.
As it is usable I won't be rushing into a new LCD. But interesting they are available off the shelf in Oz from their service agent shows them to be a failure point.
« Last Edit: November 01, 2019, 09:17:50 am by beanflying »
Online tggzzz
« Reply #42032 on: November 01, 2019, 09:22:30 am »
I unpacked the 184, which was boxed up quite nicely, and took a few photos. Thread to follow. It was definitely stored in less than ideal conditions - incredibly crufty slide switch contacts, for example - but is not in bad shape internally.
Building a compact, stable, clean 500MHz oscillator in 1965 was a challenge, so it is full of interesting looking circuits.  I am going to enjoy working on this one.  :-+
The switches are a bit of a pain, but the inside is fun to look at. I even posted a picture of one particularly "innovative" bit of mine.
Given the capacitor-like things are nuvistor valves, and there is interesting very exposed metalwork inside, be careful where you put your finger/probe/screwdriver :)
« Reply #42033 on: November 01, 2019, 09:28:46 am »
Would a pedestal under the Atmel chip give enough support ?
« Reply #42034 on: November 01, 2019, 09:42:45 am »
It is more the reverse needed as the Atmel faces the LCD. The white clips on the LCD frame are all that keeps the zebras tight. So forcing the PCB low and wedging the LCD high is worth a go. I have some 4 thou Mylar sheet so I can jack the LCD in small increments and see if it helps providing I can get the PCB to stay in place with the limited supports.
« Reply #42035 on: November 01, 2019, 09:47:59 am »
Hmmm, understood. It's enough to drive you to drink but a clear head is heeded for a lasting fix.
Sleep then coffee should help.  ;)
« Reply #42036 on: November 01, 2019, 10:38:25 am »
Yah, just had comfirmation that my Thurlby 1905A bench meter is out for delivery today and is currently only 63 deliverys away..... :-+
« Reply #42037 on: November 01, 2019, 11:06:20 am »
Good advice.
But they don't suffer from ruby red LED issues.  :-+ :-DD
« Reply #42038 on: November 01, 2019, 11:12:28 am »
I found the issue with this 8800A and the wild readings on the 200V range. Extremely dirty switch contacts. Took several applications of Deoxit D5 to clear it up. So far it's working. If it continues to work fine....if not....I'm prepared to sacrifice the drifty 8810A as a parts mule. But we'll monitor it.
Today's objective is a complete calibration check of both 8800A's.
« Reply #42039 on: November 01, 2019, 11:14:16 am »
Good advice.
My new Thurlby has ruby red LED's and I sure hope that it dosent have any issues with them as its game over then as they are obsolete specials  :-DMM
« Reply #42040 on: November 01, 2019, 11:17:02 am »
Good advice.
As far as I know most Fluke LED's are generic and readily available.
« Reply #42041 on: November 01, 2019, 11:48:24 am »
Don't worry - they're still available and quite cheap!
https://www.ebay.co.uk/itm/273992960208
Plus the type of module is a simple multiplexed one so with a couple hours in Kicad and a JLCPCB order you could retrofit different displays easily.
There's nothing nasty in the 1905A AFAIK. Even CPU is a 6502 + 6522 VIA + EPROM + normal 74LS  :-+.
edit: the front panel / keyboard looks like the only risk.
« Last Edit: November 01, 2019, 11:51:36 am by bd139 »
« Reply #42042 on: November 01, 2019, 12:05:06 pm »
And since it's British made you'll probably need them.  >:D >:D :-DD
(exiting before the lynch mob catches me  :P :P :-DD)
Offline factory
« Reply #42043 on: November 01, 2019, 12:21:48 pm »
While both the HP34401 and the 34410/1 have been subject of many posts, even comparing them, has anyone here had experience of working with the 34465A? There are tempting offers, albeit from far away places out there!
I am slightly annoyed by the fact that you can only find overviews within a generation of instruments. I would really like to see HPAK gear getting such a complete, reliable and useful treatment as the Tektronix products are getting on TekWiki.
Btw, there is another one of the Thurlby DMMs upcoming.
If thats the one on eBay UK, then be aware that it looks like it has display issues with segments of the LEDs not lighting up.
Could it be the due to the camera shutter settings & the display being multiplexed? :-//, the description doesn't mention anything about display problems.
« Reply #42044 on: November 01, 2019, 12:58:45 pm »
Yeah it could be due to camera settings, I had the option of getting either one, I chose the slightly dearer one which photographed perfectly and looks the best overall condition, almost mint infact.
« Reply #42045 on: November 01, 2019, 01:02:01 pm »
Thats a great releif, I read it somwhere in a review or repair thread about them being unobtainable but those on eBay are the right ones  :-+
« Reply #42046 on: November 01, 2019, 01:02:34 pm »
So true. We even take the piss out of ourselves over it:
The following users thanked this post: worsthorse, nixiefreqq, factory
« Reply #42047 on: November 01, 2019, 01:27:46 pm »
So blue PLA arrived  :-DD. Printing NanoVNA case!
The following users thanked this post: med6753, mnementh
Online Ditiris
« Reply #42048 on: November 01, 2019, 01:31:05 pm »
Time to discovering EEVblog to dropping $3k on test equipment - almost a month. I'm proud of myself for resisting that long.
« Reply #42049 on: November 01, 2019, 01:56:08 pm »
Oi !  Blooming cheek...
I'm not a fan of this type of membrane keyboard myself, but it seems to work fine.
Only thing I would mention, is that the header has 1 more pin than the cable connector, so make sure you observe which end has the extra one if you disconnect it...
EDIT:
Only $3k? You're not trying hard enough...   :-DD
« Last Edit: November 01, 2019, 01:59:41 pm by ThickPhilM »
