Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 17685722 times)
onsokumaru, Vince and 27 Guests are viewing this topic.
« Reply #38775 on: September 13, 2019, 12:17:46 pm »
Just got D75. 100% write off. Caps have destroyed the board. The guy did a fairly good repair attempt on it with some decent Kemet caps but didn't clean up the mess. It has wicked up the transformer wires and they are all crumbling  :--. Absolutely no way of saving this one.
I know people who need parts for these so I'm stripping them down and doing that instead.
Gonna pursue a refund?
« Reply #38776 on: September 13, 2019, 12:19:22 pm »
I cannot understand this. Using decent parts, change them on the board but do not cleaning the mess from the spilled out electrolyte?  :palm:  :-//
It should be really obvious to clean this mess first before solder any new parts.
« Reply #38777 on: September 13, 2019, 12:26:00 pm »
Nah not at all. It was listed accurately. The seller was honest about it. I took the risk so it's fair. My plan B was stripping it so I will proceed with that. It's got a lot of decent grade sheet alu in it and a ton of decent transistors - cheaper than buying them :-DD. I know a few people who need parts for D83/D83 anyway so it's going in that direction too. Either way, I get a good enough win out of it  :-+
I think the damage was done a long time ago. I had a D83, many pages back in this thread, that the same thing happened to. The shitty Plessey caps leaked in it. The PCB was and transformer wires were buggered way before he tried to repair. He picked good caps and soldered them in well but damage was done so he gave up. You win some, you lose some.
Two of the wires broke off when I moved them. So I figured it was just the joints. So I cut 2mm off the end then stripped them and the wires are powder inside  :--. This was repeated a few times carefully until I reached the transformer - there's not even enough to lap solder some new wires on.
« Last Edit: September 13, 2019, 12:27:58 pm by bd139 »
Offline SilverSolder
« Reply #38778 on: September 13, 2019, 12:32:44 pm »
[...]  It has wicked up the transformer wires and they are all crumbling  :--.   [...]
No way of opening the transformer and putting new leads on it?  Probably won't have affected anything inside...
« Reply #38779 on: September 13, 2019, 12:55:03 pm »
Maybe thats an indication of the sort of age where that's more then likely going to be the case unless it been though the hands of one of us recently to help preserve them?
Sent from my POT-LX1 using Tapatalk
« Reply #38780 on: September 13, 2019, 01:06:32 pm »
It's a toroidal one unfortunately so would need unwrapping then reinsulating. I don't have the kit to do it and the return on the investment of doing that is low.
I've also found out that whatever goop was inside it appears to have corroded legs off transistors.
The point is moot however as someone is coming to collect it tomorrow for the plugins for what I paid for it  :-DD
« Reply #38781 on: September 13, 2019, 01:30:30 pm »
This looks rather interesting:
https://www.ebay.co.uk/itm/333188748845
Based on https://github.com/ttrftech/NanoVNA
https://youtu.be/aA4bugrGYVA
After doing a bit of research, I decided to buy one of these (the original developed by Hugen) and compare it against the DG8SAQ VNWA.  Even if it is only good to 50MHz it will be a useful piece of gear to have in the field. Plus it reminds me of all the small, interesting Autek kit from long, long ago.
834396-0  I was actually thinking of getting into one of those for testing CPW antennas for my FPV quads... but so many reputable manufacturers (no, seriously) hit the scene with sub-$20 kits (tuned pairs) that it just wasn't worth making my own anymore. Anything I need to plot I can do a quick thumbnail with my IRC Power Meter and a yardmeterstick... and it's already optimized for 5.8GHz.  :-//
   Mum safely under a blanket in bed so I escaped for a while.  ;D   Just what is needed for TEA cleaning" a 20L Espresso making steam cleaner.  8) Ably supporting the 90kg lump is my hydraulic lifting table eBay auction: #143029362536
And the bling shot of some of the TEA because it was in the area
>:D
Everybody hit the deck! bean's gone META!!! :-DD
No, seriously... anything could happen!!! :scared:
« Last Edit: September 13, 2019, 02:01:28 pm by mnementh »
« Reply #38782 on: September 13, 2019, 01:57:52 pm »
hey oculus
wow.....really cool instrument. however you accidently included some offensive material in the picture. no need to apologize. fixed it for you.
freqq
   That's not offensive This is offensive.  :popcorn: :-DD
Heh.
 >:D
« Last Edit: September 13, 2019, 01:59:47 pm by mnementh »
« Reply #38783 on: September 13, 2019, 03:21:51 pm »
I think according to Nixiefreqq I'm supposed to be so offended that I may have to slit my wrists.  :-// :-DD
Offline worsthorse
  • aina varma, usein väärin
« Reply #38784 on: September 13, 2019, 04:02:08 pm »
hey oculus
freqq
(Attachment Link) ]
Heh.
 >:D
hey mnem, i fixed up that TI for ya...
The following users thanked this post: GregDunn
Online tggzzz
« Reply #38785 on: September 13, 2019, 04:17:10 pm »
(Attachment Link) ]
Heh.
 >:D
Pah.
Here's my 1991 handheld computer, with a beautifully readable display, even in full sunlight. Note that it runs a full version of Lotus 123.
Weight: 290g. Weight of manual 1200g.
« Reply #38786 on: September 13, 2019, 04:19:59 pm »
Most importantly it has an RPN calculator in it.
The following users thanked this post: Carl_Smith
« Reply #38787 on: September 13, 2019, 04:24:26 pm »
Looks like the calculator war has started up again.  :popcorn: :popcorn: >:D ;D
« Reply #38788 on: September 13, 2019, 04:28:31 pm »
Started up again? It's not over until the last equals button and the button pusher is 6 feet under  :-DD
Edit: I am trying to peel an LM723. I don't have a vice so this turns out to be a hell of a lot more difficult than it looks. Trying tin opener next  :-DD
The following users thanked this post: worsthorse
Online tggzzz
« Reply #38789 on: September 13, 2019, 04:29:35 pm »
Yes, and you can see the stack and registers.
I didn't include a photo of that because it would infuriate some people  :)
« Reply #38790 on: September 13, 2019, 04:31:07 pm »
Yeah that's one thing I always liked about the 50g as well. Unlimited stack and 7 levels on screen.
Wondering if I should head over to ebay  :-DD
^^ genuine HP hat.
The following users thanked this post: bitseeker, Neomys Sapiens, GregDunn
Offline nixiefreqq
« Reply #38791 on: September 13, 2019, 04:35:02 pm »
yes.....but.......but.......but......oculus started it!
at this point the old man used to pull the car over and just slap the shit outa' anything that he could reach.
free range primate
Offline nixiefreqq
« Reply #38792 on: September 13, 2019, 04:38:37 pm »
^^ genuine HP hat.
ok....you made me laugh out loud.
ya' damn rpn freak you!
free range primate
Offline nixiefreqq
« Reply #38793 on: September 13, 2019, 04:59:18 pm »
swmbo just brought me lunch.
salad out of a bag, with some tuna out of a pouch sprinkled on top.
gidget jumped up, sniffed the damn thing, then turned and walked away.   because even she won't touch tuna out of an aluminized plastic pouch.
suspect that the rabbits out on the lawn would also refuse salad out of a bag.
ate it however.  don't want swmbo to think we don't appreciate her misguided attempt to keep me healthy.
free range primate
« Reply #38794 on: September 13, 2019, 05:36:16 pm »
Hahaha fuck Mjolnir (the HP 6286A) just took its first victim. Built a small output stage for a low power audio amp. Well it turns out I had the meter on the 12A range when I set the current limit to 800mA so it was 8A at 24V. There was a short between VCC and ground. One of the two bits of wire from the power supply just basically instantly caught fire and the place now stinks  :-DD
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #38795 on: September 13, 2019, 05:43:51 pm »
Pile-on!  :-DD
Offline nixiefreqq
« Reply #38796 on: September 13, 2019, 05:58:23 pm »
DON'T MAKE ME HAVE TO PULL THIS CAR OVER!
free range primate
« Reply #38797 on: September 13, 2019, 06:05:43 pm »
Am I still obligated to be on your side? Because it appears we are outnumbered  :-DD
The following users thanked this post: xrunner, bd139
Offline nixiefreqq
« Reply #38798 on: September 13, 2019, 06:48:48 pm »
perhaps you are right.  maybe it is time to give up the fight.
they can't help themselves.........rpn is a disease.  most were infected early in life and will never recover.
after all...... we tolerate tek-fever and fluke madness in others.  why not rpn insanity? (maybe bd can find an "=/enter" cap, and we can all just get along?)
ps  am still thankful no such illness has ever stricken me.
free range primate
« Reply #38799 on: September 13, 2019, 06:55:27 pm »
This talk is how wars start  :-DD
