These are ridiculously easy with even the cheapest hot-air setup; they're few enough pins you can either pre-tin the pads with an iron/paint with rosin or apply paste manually with a toothpick. The part will literally self align as long as you don't crank the air up so high you blow it off the board. I'm not seeing your problem...?
I do have a hot air station, an AOYUE int 852
![](https://images-na.ssl-images-amazon.com/images/I/71EPDNLNUCL._SL1500_.jpg)
I tried to solder some SMD components, some TSOP-16 stuff and found it hard to place it correctly so that
i will get nice solder joints. And TSOP is much easier than VQFN, where one have to place it to 1/100th mm
And you can't see it, if all solder joints are good. I dislike this kind of soldering. Usual SMD stuff is no problem,
but this brings me to my limits. Probably I need more practise.
If you don't have a hot air station, now's the time; this is JUST the sort of project to practice on. Just remember to populate these parts FIRST on a bare board if you're a noob. Or you can get a cheap breakout and plug it into a DIP, but that'll make your end product pretty big: eBay auction: #382865350172 For other outlines, this experimenter's kit is cheap but very interesting (doesn't have specifically QFN24): eBay auction: #272931785519
Thanks for this, I'll have a look at them.
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
And I've found also something for you:
![](https://images.8tracks.com/cover/i/002/521/046/182543_289284907835980_1877875185_n-7457.jpg)
T-Shirt @ EMP
![](https://www.emp.de/dw/image/v2/BBQV_PRD/on/demandware.static/-/Sites-master-emp/default/dw391a87de/images/3/9/9/7/399743d.jpg?sfrm=png)
"Reality is something for people who are afraid of dragons"
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
