![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=773172;image)
FUKKIN' A-DIDDY!!!
That is all.
I done more than enough of this to well know you deserve/earned this:
![](https://www.eevblog.com/forum/index.php?action=dlattach;topic=81471.0;attach=549593;image)
Why don't I ever have such luck ? ![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
Trying to understand the course of events here...
1) While attempting to remove (drive?) a screw, the shaft of the screw broke, leaving the piece visible at coordinates (26.4, 2.2) in the work piece?
2) An attempt was made to drill out the shaft, using the drill bit from coordinates (26, 1.3) to (28.2, 1)? The bit broke off in the attempt?
3) The screw shaft was then worked, using the end cutters that occupy the left side of the picture?
4) The work on the screw shaft resulted in the successful extraction of the shaft with a combination of the vice-grips that occupy the right side of the picture and the Easy-Out at coordinates (26.5, 2.2) to (28.3, 2)?
How did you get the broken end of the drill bit out? Were you able to replace the broken screw? Inquiring minds want to know.
![Popcorn :popcorn:](https://www.eevblog.com/forum/Smileys/default/EatingPopcorn.jpg)
