Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 18796106 times)
salvagedcircuitry and 143 Guests are viewing this topic.
« Reply #3275 on: October 31, 2017, 05:53:40 pm »
It’s pretty useful generally. It’s three independent floating supplies that you can parallel if you need more wumph. You are rarely at the mercy of the builder on these as Heathkit sold more assembled than they did as kits mainly to schools and university labs. The only weak point is the metering which used fixed resistors and was way out. The interesting bit is you just can’t blow it up!
Really as far as power goes it’s fine for most electronics work. I’ve used it to build and power hundreds of circuits.  I only got the Thurlby unit because I wanted better metering and some more watts per channel for building switching supplies.
I think I paid £20 for it about 10 years ago which was a good deal. £2 a year :)
Thats even more reason to retain it in your collection
« Reply #3276 on: October 31, 2017, 05:55:55 pm »
Hadn’t got anywhere to put it! :(
This is being resolved. Looking at a house next Tuesday with a large garage :)
Offline URI
« Reply #3277 on: October 31, 2017, 06:28:01 pm »
The time will come when you regret having it sold.  >:D
As long that garage won't be occupied with your fiat...then: hope the best for you and your TEA :)
« Reply #3278 on: October 31, 2017, 06:30:09 pm »
Garage is to be what 1.A garage for the car, 2.A workshop or 3. Both?
Hows you EGR? I would have thought that the car was drivable still? I blew a turbo hose on a Passat once and man, that was not at all drivable unless you crept along with the engine almost at idling speed. Go anywhere near the throttle and it was a modern tank putting out a smoke screen for self defense it was that thick on emissions, a car with a police bullseye permanently behind you.  :--
« Reply #3279 on: October 31, 2017, 06:34:24 pm »
Garage for workshop. Cars live on roads :)
EGR being replaced tomorrow morning. The car drops into “limp mode” when anything goes wrong with it. Sounds similar. I had a Land Rover Defender TD 2.5 which blew a hole in a turbo. That still worked fine. Had an extra air hole so it went faster. Then the turbo blew up properly on the way to the garage. Still perfectly driveable even if it sounded like someone shaking a sack of nuts.
« Reply #3280 on: October 31, 2017, 11:28:12 pm »
Received a strange box today from Fedex.
Triax cables! Ouch to the wallet. :-DD
« Reply #3281 on: October 31, 2017, 11:57:14 pm »
I know all about that limp home mode, I used to have as company cars Volkswagen Passats and on 2 of them I had the throttle sensor fail on me while actually overtaking someone on a 2 way road and when that happens the car goes into limp home mode so the car suddenly loses all speed rapidly and there was a string of traffic behind me and I had to get to the left hand side of the road and rapidly as there was on coming traffic as well. That situation is seriously scary I can tell you.
Since then I have had Skoda Superbs, they share the same engines and running gear as the passats but seem to be put together with a bit care and they have been totally reliable, I'm now on my fourth and I've brought the car from the leasing company last year as it really is the best car that I've had the privilege of driving and I've had Fords, Vauxhalls, Rovers, Citroens, Jaguars, Peugeot's, and Chryslers.
I can't get head around why the Passat didn't go into that mode when the turbo blew up. :-//
« Reply #3282 on: November 01, 2017, 12:07:11 am »
Probably a sensor failure prevented it entering limp mode  :-DD (last three things wrong with the Fiat were sensors)
Most reliable car I had was a Rover 416SLi in about 1995. Basically a Honda with a Rover badge ;)
Offline Mr. Scram
  • Display aficionado
« Reply #3283 on: November 01, 2017, 12:22:07 am »
All the best stuff's made in Japan!
« Reply #3284 on: November 01, 2017, 12:26:26 am »
Apart from software. The only thing they just can’t do.
Offline URI
« Reply #3285 on: November 01, 2017, 01:15:02 am »
I think I came across that lot on ebay, too.
Wasn't too hard for the wallet, if I remember correctly.  ;)
Good steal!  :-+
« Reply #3286 on: November 01, 2017, 01:40:43 am »
Good steal!  :-+
Oh, in that case, good on ya, TiN!
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #3287 on: November 01, 2017, 03:51:58 am »
At 77$ it was essentially free. I was surprised nobody bid.
Offline URI
« Reply #3288 on: November 01, 2017, 07:05:16 am »
I was tried by that offer because I needed a Triax connector for my newly acquired HP3437A but had no use for the rest of that bunch and a single Triax plug is less then 77$.   :)
Sometimes still able to stand TEA..!  :-DD
Offline GreyWoolfe
  • NW0LF
« Reply #3289 on: November 01, 2017, 08:41:12 pm »
I don't know if I am happy about this but I acquired my 7th DMM, an HP 3466A for $30.  Some contact cleaner and vigorous button pushing now has the proper indicator LED matched to the proper function switch press.  I have 2 hands and 2 eyes, why do I have 7 meters?  OK, 6 meters on the bench, the 7th is in my company van.  I don't wanna be a TEA, I don't wanna be a TEA, I don't wanna be a TEA.  I do like the pretty red LED display, mmmmmmmmmmm.
« Reply #3290 on: November 01, 2017, 08:50:34 pm »
Nice one. I rather like the old HP LED meters. Keep getting outbid on the damn things.
Boring week here. Bought a little unexciting dual rail fixed 15/-15v supply to run a data logging project I have off so I can free up the bench supply. Did consider building one but it was coming up at around £50. There is literally NOTHING on eBay of interest at the moment. Boo hiss.
« Reply #3291 on: November 01, 2017, 09:01:23 pm »
Good glad to hear that a spot switch cleaning did the trick, so the ACV is now working, now to fix the missing battery, is the charger/switch over board present along with battery retaining bracket? Mine had a duff battery but after a spot of re jigging I was able to get a sealed battery and modify the cables to accept it. Very nice meter.
« Reply #3292 on: November 01, 2017, 09:16:13 pm »
I don't know if I am happy about this ................................. I don't wanna be a TEA, I don't wanna be a TEA, I don't wanna be a TEA.
Too late, you're one of us now.  :)
Resign to it and enjoy.
Offline djos
« Reply #3293 on: November 01, 2017, 09:48:17 pm »
What do folks recommend for contact cleaner? I assume it is a deoxidiser of some description?
« Reply #3294 on: November 01, 2017, 09:56:55 pm »
Well I've used WD-40's Fast Drying Contact Cleaner in the past successfully but now I'm trying Servisol Super 10 which also lubricates the contacts.
The following users thanked this post: djos
« Reply #3295 on: November 01, 2017, 10:05:03 pm »
I use the WD40 brand contact cleaner as well. Doesn’t gunk up or destroy plastics.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #3296 on: November 01, 2017, 10:39:24 pm »
Meh.  You're here now.  You might as well take off your coat, pull up a chair and stay a while.   >:D
-Pat
Offline ChrisLX200
« Reply #3297 on: November 01, 2017, 10:54:42 pm »
I also use Servisol Super 10, seems to be very good. It fixed a messy problem with my daughter's Nintendo 3DS which she spilt Coke over then left for 3 weeks before saying anything...
So it was all gummed up and the switches didn't work (it wouldn't even power up). I used the servisol to clean up and the swiches all worked again.
Offline khs
« Reply #3298 on: November 01, 2017, 11:10:32 pm »
No, it's not TEA.
Imagine a device with -12V, +5V, +12V and +24V plus input voltage.
All together you NEED 5 DMM's. One DMM is in your company van, so 6 DMM's.
One DMM is no DMM.
So there is no TEA.
It's CTEAM:  Commercial Test Equipment Acquisition Management.  ^-^
Offline GreyWoolfe
  • NW0LF
« Reply #3299 on: November 02, 2017, 12:20:36 am »
You know you are lying to yourself, there is always something of interest on evilBay if you look hard enough. :-DD  My meter was at the local surplus store.  It was there for almost 2 weeks.  I think no one bought it because unshielded test leads were loose in the banana jacks.  I have some banana plugs from Frankie that fit perfectly so I cut off the ends to the test lead set I got for free with it, cleaned up the probes and put the better plugs on.  Now I have to work on replacement caps for by HeathKit IG 4505 Oscilloscope calibrator.  There are 2 bulging electrolytics so I am going to replace all 4 of them.  The volt out side works fine on my scopes, the time out side needs a little help and hopefully the cap replacement will fix that.  I also plan of replacing the cable with a BNC connector.
-Pat
OK, I will pull up a chair, but I don't own a coat, it doesn't get cold enough in Central Florida for me to wear a coat.  I don't even own a long sleeve shirt!
No, it's not TEA.
One DMM is no DMM.
So there is no TEA.
So, since 1 of the 6 on the workbench is actually for working on company equipment, that means I have only 5 for me.  5 is less than 7 so I don't really have TEA yet.  I would need 1 more for your scenario, so you're right, it isn't TEA.
