Labels 4 Mnementh including the point at which smoke may begin . Mooning shot for Specmaster.
Short riser block/mount for the pair of fans to be made when they arrive.
So, gonna mount the fans push/pull through the stack, or did you actually drill holes in the base of that lovely casting?
Still not too late to make it all horizontal to fit on a shelf... Then you'd have room for a panel meter.
I do sincerely wish you luck not smoking it, however... all this tinkery does make my experiments with soggy coils of coathanger seem much less unreasonable, doesn't it?
Actually, those LED ballast resistors are pretty robust; they'll take quite a pounding. But I know from experience that this fact invites abuse.
