Just modded my Heathkit VTVM so I dont have to keep switching input jacks for measuring AC and DC and while I was in there I decided to replace the MES bulb for the power indicator to a green LED to release a few more mA for the heaters. The power LED is not very bright and thats due to the original design of the meter.
The 1/4" jack is retained so the use of a RF probe (assuming you have one) is still possible.
The 1M resistor that was in the old probe that used to use the 1/4" jack for DC measurements is now fitted internally across the DC 1/4" jack and the AC-OHMS jack. I'm not too sure just what effect this would have with an RF probe connected as I don't have one to try it with.
The big advantage with this modification is that it enables a standard set of leads with finger protection and better grips to be used (if they have shrouded banana jacks, trim the shrouding off) without having to unplug them when switching between DC and AC volts and or Ohms ranges.
As always with these old metal cased test instruments care needs to exercised as the common jack is also connected to the chassis and infact the chassis forms the return path for the 1.5v C cell that is used for the resistance range, so care must used to ensure that when measuring AC voltage, the neutral is always plugged into the common otherwise the entire case will become live.
Important Update
If anyone does these modifications, beware that there is an inherent safety issue when measuring AC volts, the case could become live with the 1/4" jack socket left in place as the battery negative uses the chassis and case as its connection to the meter. This means that the common socket is still connected to the chassis via the 1/4" jack it could become a hazard while measuring AC voltage, particularly if the lead connected to the AC live pole was to be plugged into the common socket then the chassis and case would be live.
To cure this potential problem, I have decided to remove the 1/4" jack socket, which was originally retained to allow the use of a suitable RF probe, and in its place I'm fitting a 10mm LED panel indicator 6v to be wired across the old connections for the 6v MES bulb that previously served as a power on indicator. The old battery holder, (spring and C cup) is being removed and all insulted AA battery holder is being installed and the negative terminal will be wired directly to the common terminal, thus removing all connections to the case and chassis so removing any shock hazard.
I may also replace the current 2 core mains cable and fit a 3 core and earth the chassis, while this is strictly not essential as the whole VTM was designed in the first instance to be a insulated system, although this potential hazard has always been there as far as I'm aware and I'm not aware of anyone receiving a shock from it so maybe it is as much of a problem as I perceive it to be, none the less, I'm making these changes to my own meter, just to be safe.
