Aquisitions seem to run in similar cycles round here - I also recently stocked up on Type K thermocouples!
And good luck with that Hioki! I came close to add a very much desired Siemens U-I-Functionmeter B1080 to my repair queue yesterday, but was outbid. It seemed to have some sort of power problem, which might have worked out ok.
BTW - don't all robots go by 'Robert'?
The K type probe actually ended up costing nothing (so far*), the seller noticed the parcel hadn't moved since it was collected and after having a complaint from someone else with the same problem, they opened a claim with Ervi and refunded me, they said not to bother contacting them if it arrived and to keep it.
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
*Well it looks like I need to buy more TE, none of my handheld DMMs have a temperature measurement function
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
, all my DMMs are in the post linked below.
https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/msg3589932/#msg3589932Not heard of the B1080 and google search isn't helping much, can't find much for the Hioki 8220, even the Hioki website has nothing except a Megohmmeter that has recycled the model number, bit like HP with their computer/printer carp using the same numbers.
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
It dates from the mid 90s and having read the instructions, the only way of getting the logged data off the meter is to use a printer, the Centronics cable was included.
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1577050)
I've had a quick look inside.
An overall view of the mainboard, with data back-up cell (probably very dead), underneath is the switch/button board.
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1577056)
One of the two input channels, with some of those expensive fuses, quite a few HP optocouplers used for each channel.
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1577062)
Power supply section using Maxim buck regulator and the step-up supply for the CFL display backlight. Not sure about these
Panasonic Panapissy capacitors type HFQ, the type HF in stuff at work are a change on sight component for me, seen far too many incontinent ones, all dating from the early 90s.
![Flogging A Dead Horse :horse:](https://www.eevblog.com/forum/Smileys/default/DeadHorse.gif)
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1577074)
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1577080)
Can't see much of the display board, the AA leaktube compartment fits in the space here.
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1577086)
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1577092)
P.S. triggered the google Robert
random event again
![Roll Eyes ::)](https://www.eevblog.com/forum/Smileys/default/rolleyes.gif)
, now got 216 ICs listed, 141 different types, sorted the LibreOffice calc sort problem, had a column that I started listing just the numbers, than formated the column to text. The sort function ignored this & though some were text & some numbers, typing the ones it thought were numbers in again sorted it.
![](https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/?action=dlattach;attach=1577098)
