sorenkir, EE4all, Vince and 19 Guests are viewing this topic.
You guys seem to having a love fest with your BM867's. Might I suggest you 2 get a room?? Even though this 465 still needs more work on channel 2 I wanted to get some “case on” burn-in cycles done in an attempt to shake out any other additional weak components. So it's gonna sit as shown for a few hours and probably do several more cycles. Now my equipment no only has to function well but it also has to look decent too. The case on this 465 looked like shit. But no more. Sprayed the entire case. You can see the contrast between old dull paint and new in the 2nd photo. It really turned out looking good.
3478A missed three things for me: non GPIB interface
no safety banana plug ports meaning I could reuse my probes.
It is excellent. Totally happy with mine too. Know what you mean about the backlight but the fluke is wishy washy too. Was a bit worried about the small knob because I have banana fingers but seems fine. Very very solid bit of kit. I did some comparisons between my Keysight jobby and that this morning on a 2200uF cap and the Keysight took 23 seconds to range to it. BM867 took 7. Smaller caps are instant. Will do a whole series of these tests over the next few days if I get some time.
Quote from: bd139 on July 12, 2018, 04:49:46 pmIt is excellent. Totally happy with mine too. Know what you mean about the backlight but the fluke is wishy washy too. Was a bit worried about the small knob because I have banana fingers but seems fine. Very very solid bit of kit. I did some comparisons between my Keysight jobby and that this morning on a 2200uF cap and the Keysight took 23 seconds to range to it. BM867 took 7. Smaller caps are instant. Will do a whole series of these tests over the next few days if I get some time.No. Not "banana" fingers. Similarly shaped object, though.
Quote from: mnementh on July 12, 2018, 01:48:21 amThe 800 is 35W EDP, the 900 is 50W EDP. Mind you, with the SmartHeat setup, 35W is equivalent to 60-70W resistive. The 800 has a plastic housing and cheaper build on the handset; which means of course that it's still like filet mignon compared to the China T-12 clones.yep, 35W Metcal is perfect and it gives me more soldering time with batteries. Also the magnetic energy saving stand will save me battery juice I hope.Sorry about your buddy, when God took us something away we should think how much He gave us.
FUUUU**!!!I just checked on my Fluke 189; turns out it has already been delivered and is in my mailbox. Problem is... we're right now having torrential rains and the street is flooding. AGAIN. mnemIs it worth drowning for...
8051 FTW. That was the first microcontroller I ever got to use. Had to blow bloody EPROMs back then Been playing Metcal + cheapo aliexpress SMD practice boards this evening. Annoyingly the 0402’s were wired in series and were capacitors. Also a whole strip of 620 ohm resistors was missing. Fortunately I dealt with this the proper way which is to buy everything from China in twos. The other kit was ok. Flashy LED fun. I have overcome my fear of 0402s. I did this board with no magnification https://youtu.be/0n3dkB6kuLw
Quote from: bd139 on July 12, 2018, 05:55:24 pm3478A missed three things for me: non GPIB interfaceThe HP3478a does have a GPIB interface.
Quote no safety banana plug ports meaning I could reuse my probes.Or better yet buy a pair of Probemasters with the retractable shrouds.
Quote from: mtdoc on July 12, 2018, 06:48:47 pmQuote from: bd139 on July 12, 2018, 05:55:24 pm3478A missed three things for me: non GPIB interfaceThe HP3478a does have a GPIB interface.If I'm not mistaken, bd wanted there to be an interface other than GPIB. e.g., 34401A has RS-232 as an alternative I/O port.Quote from: mtdoc on July 12, 2018, 06:48:47 pmQuote no safety banana plug ports meaning I could reuse my probes.Or better yet buy a pair of Probemasters with the retractable shrouds.+1. That was my solution to the jack compatibility problem.
Quote from: bd139 on July 12, 2018, 09:22:42 pm8051 FTW. That was the first microcontroller I ever got to use. Had to blow bloody EPROMs back then Been playing Metcal + cheapo aliexpress SMD practice boards this evening. Annoyingly the 0402’s were wired in series and were capacitors. Also a whole strip of 620 ohm resistors was missing. Fortunately I dealt with this the proper way which is to buy everything from China in twos. The other kit was ok. Flashy LED fun. I have overcome my fear of 0402s. I did this board with no magnification https://youtu.be/0n3dkB6kuLwNice work, is there a real purpose to the flashing leds at the end of it all or is just a circuit that you have to build and they only flash if you have it correctly connected? Those 0402's look bloody scary, only have to breathe on them and they move before you tack them down.I reckon it would be easier and quicker to use solder paste and a hot airgun, have you got a hot airgun?
Quote from: bd139 on July 12, 2018, 05:55:24 pm3478A missed three things for me: non GPIB interfaceThe HP3478a does have a GPIB interface.Quote no safety banana plug ports meaning I could reuse my probes.Just get a pair of these.Or better yet buy a pair of Probemasters with the retractable shrouds.No backlight is a bummer but others on this forum have added one without much difficulty.
That’s the first 0402s I’ve done and it wasn’t that bad. Only lost one on the floor Flashing is just to test it works. Not sure I like the idea of hot air for this. Reckon everything will just blow away instead
Quote from: bd139 on July 12, 2018, 09:56:37 pmThat’s the first 0402s I’ve done and it wasn’t that bad. Only lost one on the floor Flashing is just to test it works. Not sure I like the idea of hot air for this. Reckon everything will just blow away instead Hmm, I reckon you could turn down the air flow enough to stop them blowing away. The past would hold them in place and as soon as the paste flowed, they would all self align nicely as well without any fear of bridging.I might give it try one day, need to get to grips more with SMD myself as I've always done THT in the past and that is dying out
I just found out one of my old RC Model flying buddies from San Antonio passed away this morning; I was just talking with a mutual friend of ours yesterday and intended to call him this afternoon.
Weird thing... I contacted that mutual friend out of the blue after not speaking with him for over a year because I'd found some old analog camera lenses and thought of him; guess I should've been thinking of ol' Rick. I've spent all afternoon looking through my videos from the time; it's crazy but all I could find of him was a few off-screen comments and a brief blurry pan where he's on screen for half a second.
lor]FUUUU**!!![/coI just checked on my Fluke 189; turns out it has already been delivered and is in my mailbox. Problem is... we're right now having torrential rains and the street is flooding. AGAIN.
Quote from: Specmaster on July 12, 2018, 10:20:31 pmQuote from: bd139 on July 12, 2018, 09:56:37 pmThat’s the first 0402s I’ve done and it wasn’t that bad. Only lost one on the floor Flashing is just to test it works. Not sure I like the idea of hot air for this. Reckon everything will just blow away instead Hmm, I reckon you could turn down the air flow enough to stop them blowing away. The past would hold them in place and as soon as the paste flowed, they would all self align nicely as well without any fear of bridging.I might give it try one day, need to get to grips more with SMD myself as I've always done THT in the past and that is dying out Hot air on small components requires a soft airflow and a bit of practice but most bake them on.Just whipping through and tinning one pad with an iron then holding the part with tweezers and a quick touch with an iron tacks them down good ready for final touches.Down to SOIC is not hard at all.
