" Cheese head " ?! Lemme Google that quick.... ohhhh.... I see.
Didn't know it had a name.... hopefully I will remember it.
So I guess a BTR screw could also be called a hex cheese head ?!
It's funny the Brits gave it a food name, given food isn't exactly their prime interest, and the French who compare anything and everything to food... don't give screws food names...
The world is upside down...
Nope didn't find a BA screw... not that I expected to. The BA ones I remember salvaging from that TE the other day, were larger diameter ones.
However it took only 30 seconds to find two perfect metric candidates, and matching nuts. Same length, same cheese head, just the nearest size up.
Only a tiny bit larger in diameter. Actually I could engage them in the BA thread in the plate !
But I preferred to drill out the old thread to get a clean hole for the screw to pass through.
I voted to replace both screws for consistency's sake.
Fitted that, then fixed the broken/lifted pads and traces, the amp should be back in business now, at last !
Just need to order a couple 4 pin DIN plugs to connect the 303 power amp to the 33 pre-amp, and I think that's about it !
Getting there at long last...
Midnight, going to bed....
