Yes, these do buzz a bit.. When ever I have repaired any of the Fluke calibrators, the first thing I do is really carefully check all the aluminum electrolytic caps. Most of the small ones will need to be replaced. Also check for overheated carbon comp resistors, a common problem with these. Relays can also be a headache.
