Fraser,
Yes sir that was a close one!
Thanks for all the info. Its nice to see there is someone out there that wants to help newbies.
Here is what I have so far:
EXTECH EX520 Multimeter
Fluke 110 Plus Multimeter
Cheap Digital Multimeter that I hook my home-brew RF probe on
Anti Static Non Magnetic Ceramic Screwdriver Set YR 034 105mm 4"
Belden RG-174/U Miniature 50 ohm coax for making probes and such
RF Sampler 1-30 MHz Sampler
LC100-A Digital LCD High Precision Inductance Capacitance L/C Meter Tester
EZ Digital OS-5060A Analog Oscilloscope 60MHZ 45W
P6060 1X 10X Probe Oscilloscope Probe Kit 60MHZ Oscilloscope Sonde Tip
Fluke 1900A Multi-Counter
Semiconductor Tester Model 72-965
2in1 Soldering Station Rework Hot Air & Iron 852D
Weller 45W Soldering Iron
Mark IIB Wattmeter
PDC600 SWR/Watt/Modulation Test Center
Astron RS-50A Power Supply
Kem Tron FC-50 Freq counter
2 Micronta Fet Volt Meters
Sylvania SWR-Field Strength meter I converted to use as a RF probe
PDC1 SWR Meter
1000 Watt Dummy Load
2- 100 Watt Dummy loads
M328 DIY Kit Capacitance ESR Inductance Resistor LCR Meter Component Tester. Still waiting from Hong Kong.
HP 8656B Signal Generator 0.1-990 MHz
Edited to add a few things I missed and plus say my offer was accepted for the Sig Gen. Doing the happy dance
![Clapping :clap:](https://www.eevblog.com/forum/Smileys/default/clap.gif)
