SG-505: I've seen the price people are ready to pay for it and seriously, you can build your own sine generator with same / better specs(*) for less money than that, probably even if you put your work hours on the imaginary bill.
(*): Ultra-low distortion oscillators are limited by two factors, mainly:
- THD caused by active elements in the oscillator itself (i.e. op amps), not really an issue today anymore with the LM4562/LME series and some extremely good discrete designs
- THD caused by the gain/level control. Mainly caused by residual nonlinearities of the controlling JFET (solution: select it!) and ripple in the control voltage (solution: filter more, use more inputs to the rectifier, for example, in a state variable oscillator, rectify the quadrature signal, too. And it's inverted counterparts etc.)
