Author Topic: TEKTRONIX THS710,THS720,THS730 External Battery Charger Build  (Read 1101 times)
Offline zyxel13Topic starter
  • Country: at
In a Previous Video is showed my 1:1 Drop-in LED Backlight Controller for the THS7xx Series of Tektronix Isolated Scopes.
Today I want to show my Design & Build of a External Battery (Accupack) Charger tor these Scopes.
It can be Powered either from a Wall-Wart  5V or 12V Power Supply, the default is the 5V PSU with ca. 2Amps. If a 12V one is to be used, a onboard DCDC (Mini360) Buck must be populated along with 2 Caps.
I used a Standalone Charger Chip (Asian Brand) that offers all the Features I wanted, the only drawback of this Chip is the limited Status Signaling, just Charging or Charged.
This problem I solved with an additional ATTINY85 that takes care of the Signaling using a WS2812 type Intelligent LED.
Green Blinking : Battery not detected or not Inserted
Blue Steady : Charging
Green Steady : Charged
Red Steady : Output or Battery shorted or Battery too low inner Resistance
Hexcode for Tiny, Steplfiles, STL Files, Gerbers & BOM are available on Request.
Attached Pictures and 2 Videos of the Charger Build.
Cheers,
Konstantin
« Last Edit: April 30, 2023, 04:55:26 pm by zyxel13 »
The following users thanked this post: eliocor, dermitza, TERRA Operative, AVGresponding, DH7DN
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
Re: TEKTRONIX THS710,THS720,THS730 External Battery Charger Build
« Reply #1 on: April 30, 2023, 05:52:14 pm »
This is really cool.  :-+
