I recently got a THS3024 and accessing the console or running its software from Windows 10 and 11
was not possible because drivers were only available for old Windows versions.
The Scope has an internal FTDI chip converting USB<->RS232.
The old XP/Win 7 drivers provided by Tektronix are just the FTDI drivers but using Tektronix hardware identifiers
VID_0699&PID_3012="Tektronix THS3012 oscilloscope"
VID_0699&PID_3014="Tektronix THS3014 oscilloscope"
VID_0699&PID_3022="Tektronix THS3022 oscilloscope"
VID_0699&PID_3024="Tektronix THS3024 oscilloscope"
I took the modern x64 FTDI drivers, added Tektronix IDs and it worked.
For installation just run "install_3.cmd" on an elevated prompt (for this just open a cmd instance as admin)
For de-installation you can run FTDI CDMUninstallerGUI_v1.5.exe adding the corresponding Tektronix identifier ( VID & PID #s) from the ones mentioned before.
After driver installation and connecting the scope to the Windows 10/11 x64 PC you'll see the Tektronix THS3000
in the Device Manger as shown below.
Console access and Tektronix Openchoice Desktop Application TDSPCS1 - V2.8 work
Best,
Pat
