Author Topic: A tool for designing arbitrary waveforms  (Read 1538 times)
Offline WarhawkTopic starter
    • Personal resume
« on: November 29, 2018, 01:34:55 pm »
Hi guys,
I am looking for a software which would help me with designing arbitrary waveforms for my AWG from Rigol (dg1022u). I know that Rigol has the UltraWave package but I could not get this bloody tool running. Neither under wine, nor in Windows 7. It just reports some exception handler and crashes. Does anyone have a tip for software which allows graphically drawing different waveforms and exporting them into some readable format? If it ran in Linux, it would be brilliant.
I googled but probably could not figure out the right magic formula.
Thanks, Jiri
Offline joeqsmith
Re: A tool for designing arbitrary waveforms
« Reply #1 on: November 29, 2018, 01:37:40 pm »
Matlab? Excel?  I use LabVIEW myself.   I'm sure there are a few choices out there.
    • Personal resume
« Reply #2 on: November 29, 2018, 02:59:43 pm »
Matlab, Excel, they don't allow for drawing the waveform by hand. I wanted to avoid putting there numbers manually. ::)
Offline djnz
« Reply #3 on: November 29, 2018, 03:39:00 pm »
Offline joeqsmith
« Reply #4 on: November 29, 2018, 06:07:40 pm »
Maybe write the equations to derive the waveform?  I've used various equipment to record various waveforms that I wanted to playback.
Drawing the wave shouldn't be too bad.  Maybe just use a standard CAD package.  Save the files in a standard format and write a conversion.   Back in the stone ages, I did something similar.  Built a custom Arb and used a hand scanner to capture a waveform and then converted it.
Offline JDubU
Offline Neomys Sapiens
« Reply #6 on: November 29, 2018, 09:55:21 pm »
You could even do it in Excel, if you define a Baseline (or do it inverted), mark the cell corresponding to the amplitude with something and then write a macro giving you the non-empty cell for all consecutive columns.
Then normalize/convert to format used by generator.
(not a recommendation, but feasible nearly everywhere)
