Hi folks,
I have a TDS3014C that I recently acquired from a nearby university that had a calibration error - the error message indicated that it needed a factory cal. After a bit of struggling, I was finally able to get the unit to successfully pass the calibration routines and the unit now works great.
The only remaining issue is the error log is full of errors due to the calibration being out of whack, and I would like to clear those errors. The older TDS5XX/6XX/7XX scopes required a GPIB command "err clear" to clear the error log, but that doesn't work on this scope.
Does anyone know how to clear the error log on the TDS3000 series of scopes? I know this same question has been asked on this forum and other forums several years ago with no answer, just wondering if anybody has learned anything since then.
