Author Topic: Tektronix TCA-1MEG failed  (Read 1834 times)
Offline charlydTopic starter
« on: May 07, 2021, 09:36:20 am »
Hi i bought a TCA-1MEG adapter on ebay and when it arrived and i connected it to ch1 (tried all channels) ....it gave me the popup  like in the attachment ...
( the seller was only  intent a partly refund....)
because for me it is a new adapter, that is why this model of adapter is a unknown type for my TDS7404 because it is the first and i hope only one.
Anybody have this error also or know how to fix it?  Did i use the wrong procedure or is it a failed adapter, which component(s) needs to be swapped out?
tips and help wanted.
« Last Edit: May 07, 2021, 02:06:37 pm by charlyd »
Re: Tektronix TCA-1MEG failed
« Reply #1 on: November 09, 2021, 01:21:32 pm »
.....bump.......
Anybody  can help me ontrack and give me some diagnose info...so i can check with this adapter ?
« Reply #2 on: November 29, 2021, 10:07:38 am »
there are two components which may course the problem, i think.
a chip called  PCF-8574AT  - Remote 8-bit I/O expander for I2C-bus with interrupt
and i found a (by now famous :-( ) ST- 24C16WP -  16-Kbit serial I2C bus EEPROM.
« Last Edit: November 29, 2021, 11:17:21 am by charlyd »
Offline Kean
    • Kean Electronics
« Reply #3 on: November 29, 2021, 11:11:35 am »
If it isn't recognised, then it sounds like the I2C eeprom might be faulty or corrupted.  It is probably not too hard to connect some wires to it and try read it with an I2C adapter/eeprom reader.
There seems to be very little info about reversing the Tekconnect/VPI interface on the web.  A few mentions of similar Tek probe interfaces with I2C are in this blog post which might help you confirm the data looks somewhat valid: https://debugmo.de/2010/03/probe-hacking-part-2/
There is a teardown by forum user TiN at https://xdevs.com/review/tca_1meg/ but without much detail as he probably didn't need to do any repairs.  You could try message him to see if he knows anything more, or has a dump of the eeprom from his TCA-1MEG: https://www.eevblog.com/forum/profile/?u=26015
« Reply #4 on: November 29, 2021, 11:21:27 am »
Hi Thanks for your reply and the good tip . i asked him if he could help me out.  But maybe here somebody already have agood working dump of the EEprom from a TCA-1MEG console adapter.
if yes please contact me or help me out with the file. It would make me very happy.
https://www.eevblog.com/forum/repair/eeprom-dump-file-from-a-tca-1meg-console-adapter/msg3843410/#msg3843410
« Last Edit: November 29, 2021, 04:25:08 pm by charlyd »
« Reply #5 on: January 11, 2022, 09:03:41 am »
...bump....
anyone who can help me out with an export of the working TCA-1MEG  eeprom dump. ( 24C16WP )
please get in touch.
