Resolution Bandwidth Test Part 1
I found this test very interesting. Besides the test specs and test instructions (attachments 1 and 2), I read an articles that compares the performance of the analog filters used on older SAs, to the current digital filters (Attachment 3). On Part 2, I'll try to duplicate the example showing how the new digital filters allow the spectrums of very close adjacent carriers of different amplitudes to be viewed and analyzed and do so with much faster repetition rates than what could be achieved with the older generations.
The spec identifies the different RBW filters available (10Hz to 500kHz (1-10 steps by sequence), 1MHz, 3MHz). I did test the selectivity of each one of these filters, but I've only attached a sampling of the spectrums I obtained to illustrate the main things I found (Attachments 4-9). To check the "Bandwidth Selectivity", I didn't follow the Instructions on attachment 2 to the letter because this SA has an NdB Marker Function that allows the bandwidth at the dB level of interest to be determined automatically.
According to the spec, the "Resolution Filter Shape Factor (60 dB : 3 dB)", this is what the instructions call the "Bandwidth Selectivity", should be "<5: 1 typical". The instructions show that this is calculated using: f60dB / f3dB, for this to be less than 5, the 60dB bandwidth can't exceed the 3dB value by more than 5 times. It also states that the typical ratio is 1. I'm afraid that I never saw 1 on any of my measurements, 1 would mean that the 60dB and 3dB bandwidths are the same. As far as the ratio being <5, that checked out fairly good with some caveats. The details are as follows:
Edit: I didn't look at the punctuation close enough on "<5:1 typical", It's a colon, not a semicolon as I
thought, so it claims the ratio is <5:1 typical, which is OK, not 1 typical as I mistakenly interpreted it.
RBW = 10Hz: Attachments 4 and 5 show the 3dB and 60dB bandwidths. 143 / 10 = 14.3 not <5. So for RBW=10Hz the selectivity
is not as good as stated. With the span set to 500Hz, we have 50Hz per division. Notice that about half way between -60dBm
and -70dBm the bandwidth is about 50Hz, that would be the 35dB bandwidth of the filter and the point where we actually
have a 5 ratio. So the filter can still resolve different frequencies as specified but only for larger signals.
For all the remaining spectrums I'm not showing the 3dB bandwidth because I found out it's the same as the RBW setting or very very close. The next few possible RBW setting have an improved signal shape, and are closer to the stated spec, but still somewhat off. Starting with RBW = 50Hz specs are met for several possible settings.
RBW=50Hz" Attachment 6 shows the 60dB bandwidth, the 3DB bandwidth is the same number as the setting (50dB). 247 / 50 <5.
For the settings prior to 300Hz the specs are met, but starting at 300Hz the noise floor starts to get in the way. To get a 60dB reading with the current settings, the noise floor has to be less than -90dBm. But right at RBW = 300Hz this is no longer the case, and it gets worse from this point on, since the noise floor gets higher with every further increase in RBW.
RBW = 300Hz: Attachment 7 shows the 60dB bandwidth, the 3dB bandwidth is 300, 1700 / 300 = 5.66, not quite <5.
Even though the 60dB bandwidth can't be accurately determined on subsequent RBW settings due to the noise floor, the shape of the filter is still good, and if the bandwidth is measured just above the noise floor, the ratio between this higher level bandwidth and the 3dB level bandwidth is still <5. Attachments 8 and 9 are examples of this situation.
