I talked to the power team about this, they mentioned that the motor loads are tricky (for a resistive loads the E362xxA supplies have <1V overshoot, but motors can vary).
You should be able to get a demo of one if you want to try it out. You could parallel an E36233A's outputs to get to those power levels.
