The: MARCONI INSTRUMENTS 10KHz - 1.35GHz signal generator 2030 (The Serial Number is 119329/044 Made in Engalnd) has on the display controller board and on the controller board the eproms:
IC 12 - 44533-366D ISS 2.005;
IC 202- 44533-368 ISS 001;
IC 109- 44533-366A ISS 2.005;
IC 111- 44533-366B ISS 2.005.
What is your version of equipment? What is your display?
Could you, please help me with:
https://groups.yahoo.com/neo/groups/marconi_test_instruments/conversations/topics/6244Hi All,
I'm looking for informations about one Display for the equipment:
MARCONI INSTRUMENTS 10KHz - 1.35GHz signal generator 2030 (The Serial Number is 119329/044 Made in Engalnd).
The Display is:
EPSON ECM-A0310
(9006C0U)
Assuming it is a discontinued part:
Where can I find the data sheet?
Has anyone found a direct replacement?
Has anyone adapted a diferent display to this design?
Has anyone added new hardware to adapt a new display for this generator?
Running the test procedure it shows up the message:
**Can Not Setup Link Between Processors**
and the display shows some corrupted irregular half columns and lines as well.
I have checked all connections from the processor board to the display controller board and it matches as supposed.
The controller board has the controller IC SED1330FBA
https://www.lcd-module.de/eng/pdf/zubehoer/sed1330.pdf The pinout of the display is:
PLFM
1 plus 5 V
2 GROUND
3 VLCO
4 LP
5 FR
6 NC
7 NC
8 DIN
9 MSXCL
10 NC
11 D0
12 D1
13 D2
14 D3
I imagine a product: Display Box Interface, to convert obsolete displays to new ones.
If it doesn't exist, maybe with the information for the existing parts, we can build one.
Here is another place of information:
https://www.vintage-radio.net/forum/showthread.php?t=153435Thank you.
