Mark - many thanks.
"When you say you "can't find" it, do you mean there's no signal or you can't locate it on the schematic? LED DATA is on the snippet you posted; outlined below."
I did find the likely LED DATA signal later
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Pin 5 J652. I need to probe it on pin 2 U2210.
Is the LED clock definitely pin 16 J652?
"Maybe you could share some screen captures?"
Stand by - in a few hours.
"You can see in the snippet that CONT DATA (control data) signal is the same as LED DATA. CONT DATA, among other things, is used to control the attenuator relays. Can you hear the relays clicking if you cycle through the V/div settings? That would be a good indication CONT DATA, and therefore LED DATA, is ok as far as U2210."
Yes the buttons seem to work for clicking various relays e.g. the input AC or DC or GND mode. So it has to be the clock - or something actually on the front panel.
"I would also check for continuity from GND to J652.19, and from +5V to J652.20 to make sure the front panel is getting power (or at least getting to J652). Use the power connector where you measured the incoming voltages as your reference points."
How do you get to the front panel? I can see some screws on the bottom, but there are many buttons etc to remove. At that point I would rather pay someone who has done this before, a couple of hundred GBP... I am in the UK.
"As you're poking around, keep in mind a lot of failures in these circa scopes is caused by bad PC traces. Don't assume that if a signal or power is ok in one place, then it's ok everywhere."
Sure... OK. The internals all seem very clean on this one.
