Taking a scope break –
Very interesting - I hope you find a higher frequency source!
UpdateNow that Christmas is over I finally found some time to continue work on my second 2465B. It cleaned up real nice, except for the BNC's. I took the front panel out and disassembled it and then washed the face plate in warm water and soap. The buttons were washed and then whitened with hydrogen peroxide. The image below doesn't really do it justice but they are gray now, not that brownish-gray like before.
As a pleasant surprise both the implosion shield and the blue filter cleaned up nice too and has hardly any scratches, only a few tiny ones that are only barely visible when viewed from certain angles and in the right light. Combined with the generel cleanliness inside and lack of dust on the fan and on the boards, I'm inclined to believe that the low number of hours on and power cycles are indeed true and haven't been reset.
![](https://www.eevblog.com/forum/testgear/tektronix-2465b-oscilloscope-teardown/?action=dlattach;attach=281758;image)
What unfortunately didn't just clean up is the badge, which is a minor annoyance for now, and the BNC's. It looks like the plating on the BNC's have been eaten through by corrosion. They of course work no problem but their appearance bothers me. The image below is after polishing them once. I would like the scope looking mint if I resell it, so, I've found a source for somewhat cheap (NOS I think) BNC's but am wondering if desoldering and replacing them will affect anything? It's heating up the associated components twice after all. Or are they salvageable, and if so, using what? I've used what I had, which is a product called Silvo, that has worked fine before.
![](https://www.eevblog.com/forum/testgear/tektronix-2465b-oscilloscope-teardown/?action=dlattach;attach=281760;image)
![](https://www.eevblog.com/forum/testgear/tektronix-2465b-oscilloscope-teardown/?action=dlattach;attach=281762;image)
I've started recapping the power supply with the components I had in stock using my new ZD-915 - what a joy it is to finally have a desoldering station. My TL866 has arrived so now I await the arrival of an order from Mouser so I can finish recapping and replace the DS1225Y with FRAM.
Doing this I found some more corrosion, this time under the four 250µF 20V caps on the A3 board. All four have some black gunk around the positive lead but it fortunetly didn't spread that far and cleaned up nicely using a glass fiber brush, alcohol and q-tips. No visible damage after it has been removed.
![](https://www.eevblog.com/forum/testgear/tektronix-2465b-oscilloscope-teardown/?action=dlattach;attach=281764;image)
![](https://www.eevblog.com/forum/testgear/tektronix-2465b-oscilloscope-teardown/?action=dlattach;attach=281766;image)
